Anyone have any 350hp "Recipes"?
Old Sep 17, 2006 | 10:57 AM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
On some other forums i visit frequently, we have a dedicated thread where people post thier engine combo's and dyno's/timesheets to help other people build engines and prevent wasting time/money on useless "upgrades" like Airfoils, electric superchargers, etc. I have searched here and have not really found nothing of the like.
Personally, i dont think a performance engine is worth its weight if it doesnt have at least a 1:1 power to Cubic Inch ratio. I personally have an L98, so my goal is at least 350hp... which really shouldnt be an issue.
I am having a hard time deciding on what route to take, as there are so many. Should i do intake, exhaust, CAI, etc? Or would it be more worthwhile to just go straight to aftermarket heads and decent camshaft and headers?
If you want to participate, please post your engine build and some dynosheets and/or timeslips in this format:
Engine Size:
Rotating Assembly:
Heads:
Cam:
Intake:
Headers/Exhaust:
Computer/ECM:
Other Important Information:
Dyno/Timesheets:
Also, if you want, post the mods which you noticed made the most noticeable improvement, or if you had to do things over again, post what you would have done first through last.
If there is already a thread on here like this (which i have not seen) please dont flame and just disregard.
Old Sep 17, 2006 | 12:36 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
See signature. You should have no problem getting 350 crank horsepower. My suggestion is to buy the best heads you can afford and go from there.
Forgot to turn it on.
Old Sep 17, 2006 | 12:51 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Axle/Gears: Ford 9"
I dont see your sig, is it turned on?
Old Sep 17, 2006 | 01:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Engine Size:
Rotating Assembly:
Heads:
Cam:
Intake:
Headers/Exhaust:
Computer/ECM:
Dyno/Timesheets:
A) 350ci L98, roller block, one piece rear seal
B) Corvette L98, extensive porting. Switching to Trick Flows next year.
C) LT4 HOT cam, switching to SLP 224/232 next year.
D) TPIS big mouth ported, SLP semi-siamesed massively ported and siamesed.
E) Custom modified SLP 1 3/4" headers, custom 2.5" dual y-pipe, dual 2.5" Magnaflow cats, custom 3.5" exhaust with Magnaflow muffler.
F) Stock 7730 MAP computer with my own chip tuning.
G) Dyno and timeslip in sig.
Old Sep 17, 2006 | 05:01 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
308rwhp - 375 rwtq
in my sig,
Engine Size: 350 + .060
Rotating Assembly: stock crank -.020, stock rods with arp bolts, flat top four valve relief, stock deck
Heads:trick flow kenny duttwiler series, 1.5 trickflow roller rockers, guide plates, 3/8" screw in studs, chromoley pushrods 1-piece
Cam: lunati voodoo 227\232 @ .050, .489"-.502" lift
Intake: out of box rpm
Headers/Exhaust:2210 hooker long tube, mufflex 3" y, mufflex 3.5 catback, spintech muffler
Computer/ECM:in trash bin
Other Important Information:t-5, soon to be 3.73 posi
Dyno/Timesheets:308hp and 374tq @ rear wheels
its easy to make this stuff
thekurlyone
Sep 30, 2015 12:54 PM
level
Apr 18, 2003 05:58 PM
Josh'86IROC
Mar 12, 2003 11:50 AM
EmuMannen
Feb 23, 2002 07:44 AM
Mike92
Feb 15, 2001 05:32 PM
