Only one start a day. Need some help
Old Sep 18, 2006 | 08:22 PM
fastTbird's Avatar
Car: 89 Firebird
Engine: 5.7 TPI
Transmission: 5 speed
I can only get my car to start once a day. It take about 30 seconds of cracking the first time but it will finally start. Once started when I shut it off and try to restart I get nothing but the cranking of the motor. I have a new fuel pump in it and have correct fuel pressure. And I have spark also. Any idea. Thanks
Old Sep 18, 2006 | 09:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like it could possibly be a really badly worn timing chain.
Old Sep 18, 2006 | 10:13 PM
fastTbird's Avatar
Car: 89 Firebird
Engine: 5.7 TPI
The whole motor only has about 4000 miles on it new everything but the car does sit some. Its a project
Old Sep 18, 2006 | 10:25 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
I'm leaning towards a worn out starter.
Old Sep 18, 2006 | 10:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
not enough spark, or not enough starting RPMs from a bad starter or battery, or the timing could be off. not enough initial fuel pressure, etc etc
Old Sep 19, 2006 | 05:55 PM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Try jump starting it the second time.
Old Sep 21, 2006 | 12:06 AM
fastTbird's Avatar
Car: 89 Firebird
Engine: 5.7 TPI
Okay I traded my starter and battery in (warranty). Still having the problem. I also install a msd coil and I have 53 psi of fuel presure. I'm still lost
Old Sep 21, 2006 | 01:16 AM
Air_Adam's Avatar
53psi? that seems a little excessive to me?
Old Sep 21, 2006 | 05:32 PM
fastTbird's Avatar
Car: 89 Firebird
Engine: 5.7 TPI
I'll drop it and see what happens. I use told to run that much the cam I have
Old Oct 30, 2006 | 08:08 PM
fastTbird's Avatar
Car: 89 Firebird
Engine: 5.7 TPI
I dropped the fuel pressure and it starts fine every time. Thank you for your help
Orr89RocZ
Apr 25, 2016 08:28 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
86IROC112
Aug 21, 2015 07:20 PM
sreZ28
Aug 14, 2015 07:48 PM
mustangman65_79
Aug 11, 2015 03:17 PM
