New car to me, some questions regarding the cam...
Old Sep 21, 2006 | 02:06 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Here is the build on the car I just bought last weekend.
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. ZZ intake, Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Suspension Techniques Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with BFG G-Force KDW 245's and Tokico springs with 5 way shocks. Formerly 86SCBJN's ride.
I like the car a lot, it handles like its on rails. Its runs well too, other than a wierd electrical problem that causes a miss at lower rpms only, something or other in the ignition.
I'm curious as to what you guys think the effective powerband of this build is. The car feels real strong from 3500 on up to 5500, I haven't pulled it past there for fear of the stock valve train not liking it. What do you guys think, is that too far, does the cam support that, etc...
Old Sep 21, 2006 | 06:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's the summit 1102 I think. Look it up and find out, I think they say 1000-4000RPM or something. It's a generic cam, made by everybody out there. I would upgrade the springs on it, if they haven't been yet.
The rest of the car sounds pretty good, fun ride eh?
Slower than your TPI IROC?
Old Sep 21, 2006 | 08:44 PM
atc3434's Avatar
Car: 1986 Camaro SC
Not by much. Its softer on the very bottom, but it pulls almost as strong everywhere else, and doesn't fall on its face like the TPI350. The rest of the car is a no-contest, the interior in this thing is 4th gen leather, z28 dash, nice radio, etc. The car is way way tighter too, no t-tops, everything works, and the suspension is AWESOME. Good rubber, everything is a-ok with the exception of a weird occasional stutter I'm getting thats almost certainly the ignition. I'll track that down eventually...
Old Sep 22, 2006 | 08:20 AM
atc3434's Avatar
Car: 1986 Camaro SC
I checked it out, your are correct, that is the Summit K1102. They give a usuable rpm range of 1000 to 5500, I guess the dovetails nicely with what I've felt the motor likes. Its a crate motor, the 225hp RV cam motor originally, I have no idea what heads and valvetrain that is, I figure its probably ok up to 5500 every now and then, sure does pull strong all the way there.
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
