is this a good set up for my 305
Old Sep 21, 2006 | 06:50 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
i bought my car for 2000 and here is what it has in it
block 87 305
headers headman headers pro
intake eldelbrock aluminum i beleave its a duel flow
carb 650 eldelbrock bp
heads 350 heads not sure what type of 350 heads tho
cam hydralic
what would be a good set up to get about 300 hp
Old Sep 21, 2006 | 08:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That isn't very much info there at all.
What year is the car?
Original 305? Rebuilt? What parts are in it?
which intake? Edelbrock performer, or performer RPM? It'll say right on it.
remove one of your valve covers, and check what the casting # is on it. Should be stamped right there under the covers, between rocker arms. The last 3 digits will tell the story. Unless they're aftermarket heads, then you should be able to tell that easily.
Does it run now? Fast? I'm gonna guess here, just off the top of my head - it's a dog with 8:1 CR or so.
Old Sep 21, 2006 | 08:06 PM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
First you need to get a set of 305 heads to match the block or a 350 short block to match the heads.
Old Sep 21, 2006 | 08:09 PM
Engine: 383 stroker
Transmission: th350
the car is a 84 the motor came out of a 87 that was compleatly rebuilt 42 miles ago as for fast not sure havnt drobve it yet i still need to put my exhaust on it ithe intake is a performer rpm now the guy i bought it from said that it ran like a bat out of hell before he removed the stock exhaust he was about to put on the 40 searies flow masters on it i have the mufler i just need to put the piping in from my headers back meaning y pipe cat and my piping to my 3 inch duel tips
Old Sep 21, 2006 | 08:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
ask him what cam is in it, exactly, and then find out what heads are on it.
I'm guessing it'll be kinda slow, that may have something to do with why he sold it. but who knows right? bolt it all up and find out!
Old Sep 23, 2006 | 01:30 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Are you for sure that those heads are 350 heads? According to many sources if you were to install 350 heads on the small bore 305 your are going to experience shrouding of the valves. I have ran and would recommend highly a set of World sportsman 305 torquer heads, they are cheap, can handle a nice grind cam, and flow well with plenty of room for improvement for your smallbore motor. I noticed a stout increase after I installed those heads.
Old Sep 23, 2006 | 08:14 PM
Engine: 383
Transmission: th350
305 combo
That sounds like a great idea if you can afford it. Then find out what cam you have. You'll need some duration to make 300 horse out of 305 inches.
Old Sep 23, 2006 | 09:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
yeaaa, duration and a 305 with 350 heads - DOGS *****.
sorry, but if you are going for power, you need to make sure you have higher compression first. Chances are it's got smog dog 350 heads, and like 7.5:1 CR.
Old Sep 24, 2006 | 12:43 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It really doesn't take all that much duration to make 300 FWHP out of a 305. You just need some good flowing heads, around 10:1 compression, headers, good exhaust, good induction setup, and good tuning.
I pulled 240 RWHP/310 RWTQ out of a 305 that had a stock TBI 350 truck cam with 1.6:1 roller rockers in it. It specs 260/268 @ .008, 193/205 @ .050, .383/.401 lift w/ 1.5 rocker, .409/.428 lift with a 1.6 rocker, 112 LSA, 107 ICL. I was running a stock TBI Van intake elongated to fit the older 601 casting heads that I had ported in my garage. The intake was gasket matched to the same gasket as the heads. I also had a BBC TBI unit on a 1" tall open center TBI spacer for a 2" bore TBI. It had headers, tuning, 350 injectors, open element air cleaner and dual 3" exhaust. I was also running .040" over flattop pistons (-6cc in the 4 valve reliefs), .015" in the hole, the head gasket is steel shim and something like .027" compressed with a 3.8" bore, with the 53 cc chambers of the 601. That is right at 10.4:1 compression. 1 HP per cubic inch.
Edit, just ran the numbers through a calculator and it came out at 10.6:1 compression, YIKES, no wonder it like 93 octane and 32* timing advance. The 10.4:1 is with the 081s 56 cc chambers that were on it later. I updated the DD2000 for it. 312 HP @ 5,000 rpm and 366 TQ @ 3,500.
It pulled a 15.3 @ 93 in a fullsize van with 3.08 gears, P295/50/R15 tires and 2,000 rpm converter in the 700r4, so quite frankly, I believe the Mustang Dyno, DD2000, and even the HP based on the fuel delivery specs. 4.3 45 lb/hr injectors at 32 psi in the BBC TBI unit (1994-1995 Factory 454 Van TBI unit, regulator, injectors). That is about 75 lb/hr each and I was pushing them nearly static @ 5,000. I switched to 61 lb/hr 350 injectors at the same 32 PSI and the high RPM miss went away.
Attached are the DD2000 chart and cylinder head flow numbers.
Using lean cruise this same engine hit 22-23 MPG on highway trips more than once. I have NO doubts that it could get better than 30 on highway trips in a F-car.
I really miss this combo as it did everything well.
Attached Thumbnails is this a good set up for my 305-300hp-305-tbi.jpg   is this a good set up for my 305-mildly-porte-601-flow
Old Sep 24, 2006 | 02:15 PM
Engine: 383
Transmission: th350
Sonix - I meant use the World Products 305 heads if he can afford them. And I'll stand by my statement on duration. Not that you'll need a race cam but, more than 205 degrees @ .050.
Old Sep 24, 2006 | 05:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I did it with 193/205 or atleast got very close. 240 RWHP with roughly a 25% drivetrain loss. Consider that I had full acessories, 7 bladed mechanical clutch fan, 700r4, 8.5" 10-bolt, GM cast TBI intake, 2 bbl TBI unit, stock air cleaner assembly, and full exhaust with cats.
Old Sep 25, 2006 | 09:44 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I have a set of 87 305 tpi heads if you need them
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
colton_carlson
Mar 8, 2019 12:21 PM
Fast355
Dec 2, 2016 06:33 PM
Navy8125
Aug 22, 2015 07:13 PM
