fuel pump issue, runs constantly
Old Sep 24, 2006 | 11:44 PM
ht4100's Avatar
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
Just got the 383 in an ready to fire and behold the fuel pump runs when you hook up the battery! Any ideas as to what's wrong?
Old Sep 25, 2006 | 08:24 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Pressure regulator?
Old Sep 25, 2006 | 02:56 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Pump
Pull the vaccum hose off the pressure regulator and check for
gas.
Diaphram may be bad
Later
Irocing
Old Sep 25, 2006 | 07:42 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
The pump runs continuously when you hook the battery up? Does it run whether the key is on or off? Either way I would first check to make sure the fuel pump prime connector is not hooked to power. Then I would try unhooking the oil pressure switch and see if it stops. Did you prime the oil pump before you hooked up the battery? I don't think its a fuel pressure regulator problem as this has nothing to do with the fuel pump running. Hope this helps
Old Sep 25, 2006 | 09:22 PM
ht4100's Avatar
When you disconnect the 2-prong oil pressure switch the fuel pump will stop. The fuel pump would run constantly when you hook up the battery.
Old Sep 25, 2006 | 09:42 PM
jocool's Avatar
Ok. So looks like you might have found the problem. Sounds like you should try replacing your oil pressure switch. What does your oil pressure gauge read with the key on engine off (should go to zero)? When you have oil pressure the switch allows power to go to the fuel pump so you either have oil pressure all the time(i don't see how) or you have a faulty switch. I guess its possible for this switch to fail in the on position but it should also read funny on your gauge. It's kind of expensive(about 70 bucks), but if it were my car I would try replacing it. Also if you do get one get it from a gm dealer.
Old Sep 25, 2006 | 10:29 PM
ht4100's Avatar
I purchased a 2-prong borg-warner oil pressure switch from a local parts store for 7 bucks tonight(I've spent too much for my 383 build this year). There's two pressure switches so I hope that just this one is bad. My friend who is doing the motor swap is going to try and put it on tonight and see if that fixes it, I'll let you know, thanks!
Old Sep 25, 2006 | 10:37 PM
jocool's Avatar
Cool I hope that does it.
Old Sep 26, 2006 | 02:19 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Right on the switch. But what about the relay? Couldn't that screw up and do the same malfunction? Assuming he has the duo like I duo on my 88 TBI.
Old Sep 26, 2006 | 08:32 AM
jocool's Avatar
The fuel pump relay gets signal from the ecm when you first turn the key and only turns the fuel pump on for 2 to 3 seconds. This primes the fuel system. Then once you start the car or crank the engine and build oil pressure the oil pressure switch allows power to go through it to the fuel pump. The oil pressure switch always gets power key on or off but should only allow volts to the fuel pump if it senses oil pressure. This is why I think this may be your problem. Try pulling the fuel pump relay and see what happens. Does the pump still come on?
Old Sep 26, 2006 | 08:49 AM
jocool's Avatar
What year is your car? I am looking at some wiring diagrams and will need to know.
Old Sep 26, 2006 | 10:56 AM
ht4100's Avatar
1986
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Make sure you got the right pressure switch. Any chance you bought the low-oil-pressure switch that is used to turn on the dash light when the oil pressure drops below 5psi? That would explain why it runs with the engine stopped.
Just a thought.
Lou
Old Sep 26, 2006 | 04:01 PM
jocool's Avatar
Which engine? Does your car have a real oil pressure gauge or just an idiot light? Does it zero when you turn the key forward engine not cranking?Did you pull the fuel pump relay? If so did the fuel pump quit? Which switch did you say you replaced?
If you pull the fuel pump relay and the pump continues to run then I would still say it should be your pressure switch. If you pull the fuel pump relay and it stops then we will have to check signal coming to and from the ecm.
On 89 and earlier 5.0 and 5.7 TPI's there is a lt blue wire that comes from the ecm directly to the fuel pump. If your car came with one of these engines then the above tests wouldn't work, but since when you unhooked the oil pressure switch the pump died I don't think you are getting signal from this line although it could be checked. Boy was that a run on sentence. It will make it easier when you tell me what engine the car came with.
Old Sep 27, 2006 | 06:13 PM
ht4100's Avatar
ok, we replaced the oil pressure switch and that cured the consistantly running fuel pump. It runs for a couple of seconds when you turn the key but no longer runs constantly when you hook up the battery.
But, a new problem has arose. The car doesn't seem to have enough fuel or fuel pressure to actually make the engine run. I made another post on this. It has 24lb blue top injectors, holley AFPR, and a chip for 24lb injectors. We've tried adjusting the AFPR with no luck, Any ideas?
Old Sep 27, 2006 | 06:59 PM
jocool's Avatar
How did you determine that its a fuel problem? Did you hook up a fuel pressure gauge to the shrader valve? If so how much pressure?
Old Sep 27, 2006 | 09:08 PM
ht4100's Avatar
My friend is doing the work. From what he told me it will have a enough pressure intially but it falls off(a lot) as doesn't hold.
Old Sep 28, 2006 | 01:10 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Is your AFPR governed by vacuum? Just a shot in the dark cause no one has replyed yet. If that's the case, I would be looking what vacuum port I was hooked to and what vacuum reading it was getting. The higher the vacuum signal the less fuel pressure is needed like at idle when the vacuum is high. When you crack the throttle open and vacuum drops the PR should raise the pressure to keep up with the demand of acceration or WOT. So, if your not getting enough fuel, you might just have to much vacuum going to the regulator. OR, it might be time for one of those Walbro's!
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
