Question about extreme belt routing
Old Sep 26, 2006 | 03:08 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Is it possible to do all of the following, combined ?
1) Remove the A/C (deleting it all, not using the delete pulley)
2) Remove the power steering (convert to S10 manual steering box)
3) Install a CS144 alternator where the power steering was installed ?
And use a serpentine setup for it all ?
I'm going to get rid of the A/C, and I'm thinking of giving up on the power steering, I grew up driving manual so I'm used to it, and I need a bigger alternator.
If not possible, could one convert to V belts ? And if so, how ?
Old Sep 26, 2006 | 07:15 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
You didn't say anything about the AIR pump. Usually first on the "delete" list.
Why relocate the alternator?
You can get one good for 150 amps that will fit in the stock location?
If you don't use the AIR or A/C or P/S, you could do this:
(similar to a GM engine in a forklift)
Old Sep 26, 2006 | 08:09 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
I have to keep the AIR pump, due to my location, Cali, heck my smog test is in a week or two.
Why relocate the alternator ? Because I'd like to remove the A/C completely and not just use the delete pulley, and to balance it out, the alternator would have to be moved, and also fill the empty gap left behind after the power steering will be removed.
Old Sep 26, 2006 | 08:21 PM
Engine: 350 4BBL
It'll Probably be easier to move to Alabama... (Smog test, shmog test) What's a Cadillac converter anyway?
Old Sep 26, 2006 | 08:43 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
haha yeah I agree on that one, the emission system not only costs quite a bit if you count in the effort and cost to pass smog, but it also fills out the engine compatment in a bad way
I'd like to have a low and balanced look after I do the mods, that's why
Old Sep 26, 2006 | 08:56 PM
Engine: 350 4BBL
...I'd like to have a low and balanced look after I do the mods, that's why
Ok. Enough of the funny stuff.
There is one company that does nothing but front accessory drive stuff. I can't remember their name, but if you order anything from JEGS their flyer always gets thrown in the box. Heavily chrome plated mounting hardware & pullies for hundreds of bizzare setups for street-rods and drag cars. Several had the alternator down low where the P/S pump goes. Maybe somebody can remember their name. It's on the tip of my tongue....
Old Sep 26, 2006 | 09:01 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
delete pulley never made sense to me..
i mean, if i remove my AC, why will i want a pulley?
so yeah lemmi know if it worked out.
Old Sep 26, 2006 | 11:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
march?
zoop comes to mind
and serpentine...something...
Old Sep 27, 2006 | 12:21 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Not sure if this would work ?
Low Mount Alternator Bracket
March carries some yes, but Chevy Small Block Low Mount Alternator Bracket the price is a "little" bit too much.
However, March had this one the page:
http://www.marchperf.com/instruction...nstuctions.pdf
Maybe I could use that as instructions to make my own brackets, but if I can find some for 30 bucks or so, why not just buy them.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Jote4805
Aug 25, 2015 06:11 PM
redmaroz
Aug 16, 2015 11:40 PM
