89 GTA won't start hot or runs bad - lots of stuff checked!
Old Oct 1, 2006 | 10:24 AM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
My 350 stock GTA runs bad when hot, and won't restart (but cranks). I found a shot of carb cleaner gets it running but it will still run bad until it's cold again. I also smell fuel sometimes from outside the car after a long drive.
Replaced: cap, rotor, wires, plugs, ign module
Checked: fuel pressure (38-45psi) and spark when cold and hot, never any codes, unplugged MAF (when running bad - no effect)
None of the things checked turned anything up. I ordered an ALDL cable from ebay, hopefully that will show something.
Thanks in advance for any other suggestions.
Old Oct 2, 2006 | 09:53 AM
Car: 89 GTA
Transmission: 7004R
INJECTORS!
After reading countless threads, I found one that suggested checking the resistance on the injectors and attempting to start with the low ones disconnected. I did this and it started!!! WOOHOO!!!
I believe the kudos go to Vader from an older thread here!!!
17.4
17.3
2.0
17.3
Old Oct 2, 2006 | 09:57 AM
Car: 89 GTA
Transmission: 7004R
INJECTORS!
(it appears I posted accidentally- here's the rest)
Here are the numbers in Ohms.
_________________
| 17.4 17.4 |
| 17.3 17.2 |
| 2.0 9.0 |
| 17.3 5.2 |
________________|
(front)
I disconnected 3 injectors and it started (when it wouldn't start before!)
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
