Timing chain play...
Old Oct 1, 2006 | 02:36 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
How much play is acceptable in a timing chain? I can wiggle mine almost a half inch between the timing gears.. is this excessive?
Old Oct 1, 2006 | 02:48 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
should be next to nothing in the timing chain, half an inch means that chain is in dire need of replacement
Old Oct 1, 2006 | 03:40 PM
89RsPower!'s Avatar
Thats what I figured.. already ordered a new double roller from summit.. thanks for the reply
Old Oct 1, 2006 | 04:35 PM
ede's Avatar
ede
extended horzontily there should be around .125" deflection anything more is a sign it needs replaced. however no more than it cost if i were in a position to look at the timing set i'd replace it.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
