Dyno'd my T/A...
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Dyno'd my T/A...
i figured after the corrections for the junk TH400 tranny i'm running it should be about the numbers in my sig.. give or take a little...
the dyno tech guy said that if i spent some time tuning it he guarantees an easy 50 more HP. It's running pig rich right now... He also suggested that i go down to a smaller carb and go with a Holley instead of an edelbrock.
I have some vids on the camera, i'll get those up ASAP...
engine specs.
# 1977 LS9 350 4 bolt main
# .030" bore (355)
# Comp XR270HR Roller Cam (.495in/.502 ex)
# Comp Cams 1.52 magnum roller tips
# Comp Cams Double springs
# Bone stock 882 heads
# Edelbrock Torker1 intake manifold
# Edelbrock 750 carb
# Pete Jackson Noisey Gear drive
# Headman Longtube headers
# True dual 2.25" pipes to Flowmaster 40's dumped out the back
# Turbo 400 trans
# 2500 stall
# Hurst Shift kit
Not bad for a budget build
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i dont see much more power coming out of those heads honestly, although the holley carb would pick up some more HP for sure.
Engine: 450HP 355
Transmission: TH350
i've often thought about a vortech top end... if the wife lets me keep the car i might end up going that direction... i need to make some adjustments to my driveway first though... i have 3 cars now and she's got 1
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
bonestock 882 heads, torker intake. 240RWHP? ~300HP? I think you did pretty amazing given the parts in it.
Was that the O2 at the bottom, 8.032:1 ???
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Engine: 450HP 355
Transmission: TH350
dunno why he left the WB stuff on there, i wasn't using it... lol
http://www.superdave81.com/AV/TA%20Dyno.wmv
Vid as requested. i have another one from the front that i'll post later on...
Note the continuous downward-sloping torque curve, as opposed to rising to a peak and then decreasing....
That's what gives typical low-perf motors that great feeling of grunt when you hit the gas, and what feels like a big launch when the trans shifts; but takes FOREVER to get from 4000 to 4500 RPM, and it won't pass a 4-cyl minivan on the freeway.
That combo makes its peak torque at some RPM BELOW the dyno run.... i.e. down in the 2000s somewhere. Basically it's already done at 3000 RPM, and should be shifted at some RPM such that it returns to 3000 RPM or lower after the shift.
The fingerprint of poor flow; in this case, from the heads.
Since it's clearly not the exhaust or the cam.
Since it's clearly not the exhaust or the cam. Trending Topics
Engine: 450HP 355
Transmission: TH350
actually, if i downshift it to 2nd on the highway to pass someone it does a pretty solid job.. lol Just gotta keep it above 3K RPM and it'll pull hard till 6K
The graph says the longer you hold it in a lower gear, the less it pulls. That's the definition of "torque": how hard it pulls. That's what the graph is showing you: how hard it pulls. And how hard it pulls is, continuously less and less the higher the RPMs go.While it's impossible to know what's going on below 3000 RPMs from that dyno run, it's also highly unlikely that the peak torque occurs at EXACTLY 3000 RPM; which means it's ALREADY into its downward-sloping curve at that RPM. I.e., it's already peaked at some lower RPM, and 3000 RPM is past peak torque.
Your next upgrade should be heads.
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
