Can't find lom motor mount bolts!! HELP!!!!
Old Oct 3, 2006 | 03:33 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I putting on new headers and had removed the motor mount bolts to rock the engine. I set them down on my work bench and now I can't find them. Can anyone tell me what size they are? I need length and thread size. GM won't give a size or part number. These are the long ones that go throught the entire mount.
Old Oct 3, 2006 | 03:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oh. Those are M10x1.75mm pitch IIRC. 6" long. Actually i'm not very confident in that diameter measurement... 15mm head though right? Flanged bolt, grade 10.9 or better, pointy tip.
Not something you'd find in a hardware store. The taper/pointy tip makes it a lot easier to install.
That's total BS that GM can't help you, these aren't exactly a rare part. Call up a different dealer, that's probably your best bet.
I know one of the board sponsors (spohn or hawks I think), sells a set of these for ~$12 - nice new plated, shiny etc.
Old Oct 3, 2006 | 05:01 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
they said they could order them for me at $4 each. I can get a brand new set from ARP at the atlanta summit store for 7.88 a set. What a rip off.
Old Oct 3, 2006 | 09:12 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
went and checked the holes with a caliper, and then with a bolt. 10mm is just too small. 12mm fit pretty well. I can't find them on either of those sponsors sites, and the ARP bolts in the summit catalog don't tell you anything except they should work wit 1969-2002 chevy's with 5.7L's
Old Oct 3, 2006 | 09:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
What's the problem?
You found them - local dealership at $4per (sounds fair...), or ARP. Pick your favorite.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
