How can you tell if you have vortec heads?
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
They aren't stock on your motor, so i'd doubt it.
You probably have xxxxx187 casting heads.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Punch the gas petal and look in the rear view mirror.
If ya see a big cloud of tire smoke and suddenly you're thrown back in the seat, ya just might have vortec heads.
Examine your 89 Camaro closely for signs that it's a 96 or newer Chevy truck.
If it seems to be lacking any such evidence, then search your memory carefully for any recollection of replacing your car's heads.
If you come up short on both counts, then it probably has 187s like everybody else's.
Which are just about as far from Vortecs as you can get.
Which are just about as far from Vortecs as you can get. Thread
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
