Quick ? about cam/ converter stall
Old Oct 10, 2006 | 04:45 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
If you don't have a high enough stall conv. for your cam what will the car act like. The reason i ask is i have a comp xe274 and a 2400 stall conv. and it will barely idle in D.
thanks.
Old Oct 10, 2006 | 04:50 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
that stall with that cam will be fine but a 2800 stall or so would be better from a launch standpoint.
Old Oct 10, 2006 | 06:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It'd act like driving a stick, and letting out the clutch at too low of an RPM. It'll be kinda lazy, 'cuz it's in gear, but you're not making enough power to make it fun to drive. A higher stall just increases the "fun" factor.
It won't have anything to do with this. You probably need gobs more timing at idle, and/or to up your idle speed.
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
C409
Sep 1, 2015 03:42 PM
Jake_92RS
Aug 17, 2015 09:42 AM
