91 Rs' knocking on 93 octane
Old Oct 10, 2006 | 11:42 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i have had this 91 Rs 305 for a while now and a while back ith threw a SES light and went away has never came back but the next day it started knocking at random times and is extremly bad underheavy load uphill starts and any speed except under acceleration of more than 1/4 throttle but completly random there seems to be no power loss i have changed the fuelfilter plugs 2 times wires, cap, rotor ,msd blaster coil, i did the tbi mods checked timing it is 4* retarded with est disconnected and i have adjusted the valve lash everyway known to man i have even opened the gap on plugs to .045 and still wont go away but put Vp race gas in it and it runs like a champ no noise what so every...any ideas cause this is killing me
Old Oct 10, 2006 | 11:53 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
so is it knocking with the 93 octane, but not on lower octane? maybe your timing is to far retarted or your starving the enigine for fuel, because higher octane prevents knock not cause it
Old Oct 11, 2006 | 12:03 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
You say that you have the timing 4 deg. retarded. So does that mean that you have the base timing set to 2 deg. instead of 6 deg. ?
I'm wondering if you are running too lean... maybe the race fuel masks that. I'd look at cleaning or replacing the fuel injectors. Look for manifold or vacuum leaks too. Maybe the O2 sensor caused the SES light?
Old Oct 11, 2006 | 05:57 AM
Car: 91 RS
Engine: 350 vortec
motor knocks way worse on 87 than 93 Tbi was rebuilt 05/17/05
forgot to mention i am getting alot of pressure buildup in gastank and knock cant be reproduced with the car not moving... about the timing the only thing i have changed is the timing for the distributer. car seems a little on the rich side plugs look a little sooty
Old Oct 11, 2006 | 04:26 PM
Car: 91 RS
Engine: 350 vortec
how stiff should the AIC pintle be?
Old Oct 12, 2006 | 12:12 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
TBI engines base timing is 0, not 6. If you retarded it your running like 4 degrees retard, need to set it back. Means your plugs are firing after top dead center. If anything you should have advanced it, which would mean your plugs fire just before top dead center. TBI's generally like a few degrees advance. Reset your timing and maybe bump it up a couple degrees, then post back.
Old Oct 12, 2006 | 12:53 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Old Oct 12, 2006 | 04:43 PM
Car: 91 RS
Engine: 350 vortec
well i advanced the timing to 2* advance now it sounds like a fullblown deisel under light acceleration but only while driving...
Old Oct 12, 2006 | 06:25 PM
Car: 91 RS
Engine: 350 vortec
the car has 252k on motor and my thermostat is new but is 195* could changing thermostat help or cleaning cylinders? car might burn alittle oil so i am starting to think there could be alot of carbon buildup
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
