my car keeps eating distrubtor gears....
Old Oct 11, 2006 | 04:55 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
well this is on its 2nd disturbtor gear, stock hydr roller cam, and stock distrubtor.
stock intake manifold, all stock motor. can a cam bearing cause this?
the gears on the camshaft itself looks pretty good, what could the cause of this be?
this is the 89 iroc 5.7 tpi
Old Oct 11, 2006 | 05:07 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
wrong dist gear or the cam walking back n forth... those would be my guesses.
Old Oct 11, 2006 | 06:17 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
agreed, cam walk would do it....high volume or high pressure oil pump could cause it too. Roller cam cars had a special melonized gear, be sure your using the correct one. One other thing I have personally ran into is a bent dizzy shaft, rotor was scraping the inside of the cap and it eventually ate just a few teeth.
Are all the teeth sharp or are just a few gone?
Old Oct 11, 2006 | 07:43 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Both of the above posts are right on. First guess sounds like Cam walk. Not having the correct melonized gear would be second. In taking a guess it sounds as if your gear just went out. If that is the case it would be cam walk.
Old Oct 12, 2006 | 11:23 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
well.. ok relieved tension on the lifters all rockers are completely loose so there is no load on the cam and pryed on the back of the cam with a pry bar and it is tight as cam be no play/walk at all...
the teeth look really good on the cam itself and in my research i found that gm used an iron gear for their stock hyd roller cams. so it doesnt matter weather the distrubtor gear itself is melonized. only aftermarket billet hyd roller cams require a bronze distrubtor gear.
as far as the distrubtor gears it chews them to nothing the first one no gears were left causing the distrubtor to not even turn.
now heres the kicker it only eats 3/4 the way up going from the bottom of the gear tword the cap.
now i ran the part number for the distrubtor itslef and it is interchangeable with my orignal dizzy....more in detail the first distrubtor gear it ate was a msd distrubtor stock replacement , the second one was a u pull it yard dizzy the gears are not gone yet but you can see its eating away the dizzy gears.
Old Oct 12, 2006 | 11:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Oh man I member a similar post not long ago with the same problem. But the problem/fixes escapes me. But they are suppose to eat up the dizzy gear when it happens, easier to change it them a cam.
Might hafta dig deep in the forum.....
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
