Half juiced, but no start
Old Oct 14, 2006 | 06:25 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Working on my 87Z.
Recently I replaced the ignition switch and brake switch on the steering column along with the cable assembly that goes to the floor shifter. Hook up the battery, have interior and exterior lights, put the key in and it buzzes like it's supposed to I guess. Turn the key to start and everything goes dim, my fans dont run and the engine will not even attempt to start, dead.
Checked the rod that moves along the steering column, seems to be enguaging, moving, check the purple wire from the shifter, have a good circuit, checked the wiring connection at the ignition switch against others that I have on hand, ok. And checked the fuseable link, ok.
When I turn the key to the acc setting, the airbag system runs it's test, and the fuel pump comes on so I assume that the ecm is okay. It was running before I changed the ignition switch so, maybe I'm answering my own question. I purchaced the part from GM but, maybe I've missed something or have installed it incorrectly? Any idea's or suggestions?
Old Oct 14, 2006 | 07:31 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by Wadebryant
Working on my 87Z....When I turn the key to the acc setting, the airbag system runs it's test, and the fuel pump comes on so I assume that the ecm is okay...Any idea's or suggestions?
How did you get an '87 with an air bag? I thought they weren't available until '89 or '90.
Old Oct 14, 2006 | 08:05 PM
Wadebryant's Avatar
The car is an 87 year model. However, it now has a 350tpi w/ speed density and the steering column from a 91 GTA. The entire interior was stripped and the dash & harness, guages and air bag plus sensors are from a 90Z28.
Kind of a Heinz 57 if you will...
Old Oct 14, 2006 | 08:18 PM
Engine: 350 4BBL
...Kind of a Heinz 57 if you will...
Wow.
May the force be with you...
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
