Cruise Control Stuff
Old Oct 14, 2006 | 09:28 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
hey guys,
I took my cruise control module from my 91 TA and put it in my 92 GTA today. The module has 2 vacuum lines going to it, a 1/4 and a 5/32. The 5/32 one is a T... besides the hose feed and the hose going into the cruise control, where does the other vacuum line go?
I'm assuming this is a yes, but do both vacuum lines actually need perfect vacuum for cruise control to work?
also, I had to splice the 5 wires into my electrical system. with the key on and the cruise control switch on, do you guys know either voltage or resistance values I should be getting across each wire?
Thanks in advance
Old Oct 15, 2006 | 10:00 AM
deadtrend1's Avatar
If i can remember when I yanked mine, one line went to the switch on the brake pedal with all the wires, and the other went to the motor.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
