How come I can't pass smog?
Old Oct 15, 2006 | 10:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Luckily, the smog tech let me snap a picture of the numbers at idle, Perhaps you guys can help me figure out what is wrong?
I don't know where to begin.
Old Oct 15, 2006 | 11:02 PM
sixpackmtrspts's Avatar
whens the last time the cat was replaced?
Old Oct 15, 2006 | 11:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I replaced it about a year or two ago.
Old Oct 16, 2006 | 01:11 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Old Oct 16, 2006 | 01:43 AM
EvilCartman's Avatar
Car: '82 Z28
That's a lot of unburnt fuel
Old Oct 16, 2006 | 08:33 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you are way too rich, you may be getting some rich misfire with the O2 so high, but normally that starts when CO is up around 9.0~10.0 or more.
you need your CO down around 1.0~1.5 max with out the cat.
some things to check, is the motor getting to operating temp?
check your coolant sensor, air temp sensor, O2 sensor, fuel pressure.
check for any misfiring on the side of the motor the O2 sensor is on.
also, after you get your CO down, pull your plugs & make sure they aren't fouled out.
Old Oct 16, 2006 | 09:06 PM
Guest
Guest
Posts: n/a
Holy cow. Thats nasty. Tuned that combo???
Old Oct 16, 2006 | 11:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
post your sig TraviZ.
Old Oct 17, 2006 | 03:30 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
This sig?
Old Oct 17, 2006 | 10:37 AM
Guest
Guest
Posts: n/a
Yea, seen that before. So who tuned it? 42# injectors are like way too much for that combo and if its not tuned right you're just flooding the engine at idle which is exactly what that picture you posted is telling us.
Old Oct 17, 2006 | 02:16 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
That even beats my 75.6 HC lol
Old Oct 17, 2006 | 08:52 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Hmm. Letsee now. 230-236 cam and 42# injectors... Gotta be the AIR pump or the EGR.
Old Oct 18, 2006 | 12:32 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
The stealth ram doesn't have egr so I don't have one of them anymore. and I removed the smog pump to free some horsepower, Thinking perhaps it would only help the situation.
Old Oct 18, 2006 | 01:58 AM
Car: '82 Z28
You expected it to pass with missing smog items?
Old Oct 19, 2006 | 02:20 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
Old Oct 19, 2006 | 09:11 PM
Engine: 350 4BBL
Originally Posted by TraviZ
...Thinking perhaps it would only help the situation.
oops. My bad.
Old Oct 19, 2006 | 09:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Less strain on the engine, makes sense right?
Old Oct 19, 2006 | 10:11 PM
Engine: 350 4BBL
Yep. A whole 1/3 of a horsepower at redline. You should live here in Alabama. Makes as much sense as an A/C delete pulley. When the A/C compressor clutch is disengaged the pulley is an idler pulley. If you want to save weight move the battery to the trunk instead of pitching the compressor. The battery is a whopping 25 lbs as opposed to 8 lbs and it helps traction back there. You can have full horsepower and still keep from sweating with a simple A/C WOT cutout switch. And while you're at it, you can do like me and have it sleep the alternator at WOT freeing up about 5 horsepower.
Now, that is a meaningful amount.
(I'm glad I don't have to deal with smog stuff)
Old Oct 19, 2006 | 10:33 PM
Guest
Guest
Posts: n/a
I seriously doubt the lack of EGR or AIR has anything to do with it. I had 12ppm HC at idle with neither of those items on the car, CO was zip, didnt measure a thing.
jaridjohn
Oct 5, 2015 07:01 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
