Building engine and have a question about this unassembled shortblock
Old Oct 18, 2006 | 07:04 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Building engine, and was wondering if anyone has purchased anything from Assembly Kits, rebuilt engines rebuild or install shortblocks longblocks for chevy ford 350 , it seems like a very fairly priced website... i would like to get some opinions on if i should buy this and build the engine from there or if i should go a different route? I am looking at the 383 4 bolt...
any help is greatly appriciated since i am on a fairly tight budget to build a nice performing engine.
Old Oct 18, 2006 | 07:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's a pretty good deal.
$1000 for a 383 cast bottom end, assembled. $1100 if it's forged pistons (wonder if the rods and crank are still re-connd stock though?)
I wouldn't put a lot of faith in the 2 bolt vs 4 bolt. If you can save $100, stick with 2 bolts. You're never going to break off the main caps.
Old Oct 18, 2006 | 07:50 PM
Engine: 388 Carb
Axle/Gears: 4.10
its auctually unassembled... but I want to assemble it for the learning experience, the assembled ones arent available in the 383...
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
