pcv valve pulsates
Old Oct 19, 2006 | 01:38 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
pcv valve pulsates
Im not sure if this is normal operation or not - The PCV valve is located in the driver side valve cover. If i put my fingers on the hose for the PCV while the car is running it pulsates - kinda like a fast heartbeat. There is no oil in the hose or anything. My buddy 'mechanic' said it shouldnt be like that. ANyone know if this is normal or not????......that thebest i can explain it. thanks.
Old Oct 19, 2006 | 02:19 PM
Vader's Avatar
If you are feeling a pulsation on the HOSE for the PCV valve (with the PCV valve removed from it) there is likely a problem. I'd take my first wild guess at a sticking/leaking intake valve.
Old Oct 20, 2006 | 12:02 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
If you can feel strong pulses of air coming out of the pvc hole or oil fill hole, my first guess would be bad rings. A little pulse isn't that big of a deal... it is kind of hard to quantify this. Combustion pressure is getting into the crank case (block) somehow.
I was thinking about what Vader said... I agree.
tyeo098
Nov 30, 2015 06:27 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
