Opinions on XE274H
Old Oct 20, 2006 | 10:48 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
Opinions on XE274H
alright, ordered a 12-246-3 comp cam just 20 mintues ago... simply because it was a better cam to go with, then what i currently have and what not...
but my question is, those who have it, what are your opinions?
idle quality?
Duration @.050 230/236
Lift w/1.6 rockers .519/.523
110 LSA..
sound like a kickass cam or what?
Old Oct 20, 2006 | 11:02 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Some guys will say that is good for the street but I think in a street driven daily driver it will be to much cam for a 350.It would be better in a 383.I would have gone with the 268 but it will idle like a beast if that is what you are looking for.Vaccum should be around 9-12inches.It will lope pretty hard.You might need a vaccum canister.If you look at the comp website they made 11inchs of vaccum at 800rpms.Thats not much.
Old Oct 20, 2006 | 11:09 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
compared to the current cam, i make 8inches at 800, and 15 at 1100...
my current cam is 234/244@.050 .520/.544, but on a 114 LSA... very weak sounding idle, strong performance... but with the smaller comp cam, DD shows produces more power...
Old Oct 20, 2006 | 11:13 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I had the same XE-274 cam in a 305 pulling a 5,500 lbs brick. Ran pretty well for what it was. Idle vacuum was low, but thanks to hydroboost the brake pedal feel was 100% stock. It made 12 in/hg @ 850 RPM in the 10.6:1 305.
Old Oct 21, 2006 | 01:32 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I have an XE274 in my 11:1 350. Runs really nice - Idle has some rumble, but its not what I would call rough. It makes about 13-15" vacuum at 800rpm idle, so the brakes and PCV work just fine. I'm pretty happy with mine.
Old Oct 21, 2006 | 11:08 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
when I had my XE274 it ran great on the street. I liked to keep the idle up around 950RPM in gear which gave me a pretty smooth idle. Drop it down a little bit and it got nice and "thumpity." Power brakes worked fine I wanna say my idle vacuum was around 12-14"
I would not hesitate to use this cam again. In my opinion it is one of the best mild street/strip motor cams you can get. Great streetability and tons of power from 2500-5500RPM
Old Oct 22, 2006 | 12:57 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
awesome cant wait to run mine...
Old Oct 22, 2006 | 01:12 AM
Air_Adam's Avatar
Make sure you use some good diesel motor oil (use Shell Rottella T 15w40) with a bottle of GMs oil additive (Engine Oil Supplement, or EOS) when you break it in. The 'XE' cams are notorious for going bad when people break them in. I've done a few with that oil and GMs additive, and never had a problem.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
