Loss of power when full throtle.
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Anyone know what will cause my car to suddenly lose all power when i'm gunning it? Ill reach around 70mph and all of a sudden the engine just goes dead. It will stay like that for 3-4 seconds and all of a sudden pull REALLY hard.
I have a lot more airflow in my new engine than I did with my old.. I havent re-jetted the carb either so im probably running pretty lean.. would that do it?
Thanks in advance =]
Car: 1988 Trans Am GTA
Engine: 350 4BBL
It sounds like fuel going away from the pickup during hard acceleration.
(surely you aren't running it with 1/8 of a tank of gas or less
?)If the carb needed rejetting the engine just wouldn't make full power not completely die.
Did the carb run fine on your previous setup?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If the float bowl is empty, when it goes dead, it'll be momentarily, then it'll kinda stumble forward, as it's getting fuel trickling in. 3-4 seconds is kinda long.
It could be a very weak fuel pump, just fixed this problem on my setup (it was a weak fuel pump, and then a bent fuel pump pushrod).
Easy checks are air valve tension, and float level.
Car: 1985 IROC
Axle/Gears: no idea
Yeah, I didnt have this problem with my old engine. Now that you guys mention it, it sounds culprit that its my fuel pump. I've got a crappy stock fuel pump on her. It happens regardless of how much fuel I have, even if its full. I'm scared to work on my carb, all I know is that its responsible for mixing atomized fuel with air and sending it down my intake manifold. I mean I know a little more about a carb than that, but thats the best way of describing my knowledge when dealing with them.
Ive got a bunch of new goodies on this engine, plus the engine itself is even bigger (357 as compaired to a 350) so its probably my fuel pump. I'll probably just end up buying a holley blue or something. I'll check out fuel pressure gauges later today after I pick up my paycheck.
Thanks =]
Thanks =]
Car: 1982 Trans-Am
Yea, check the pressure first. I rigged up a T fitting with NPT fittings and hose and whatnot, using my vacuum gauge. Found 1psi at WOT, when it bogged. Just age kills the stock pump.
Isn't a holley blue an electric pump? A stock replacement would be best, I think it's a carter M6626 (I just did this last week). $26.
Car: 94 G20 hi-top conversion van
Engine: 350 TBI
Axle/Gears: something vanny
Hey, I just realized you live in Clinton Township, crazy I live in Harrison, this doesn't apply to this forum at all but its just nice to see someone here who lives so close. I just picked up an 82 trans am for $700 over on south river road, you may have even seen it! So after almost 2 years I'm back into the third gen world where I feel at home
theshackle
Sep 17, 2020 08:26 AM
ambainb
Apr 25, 2016 09:21 PM
