exaust manifold leak!
Old Oct 22, 2006 | 12:54 PM
beatercoprice's Avatar
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
Well, I heard a ticking noise and have isolated it to the drivers side exaust manifold, apprently coming from the front of the motor and not the rear.
What is a safe and tried and true way of slowly getting the bolts out without breaking them? Heat? No heat? Lots of PB blaster?
Im scared that I'll break a bolt(s) off in the head.
Old Oct 22, 2006 | 05:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd say it's a valve or rocker more than the manifold. If it's a distinct "tick" that is.
When the car is dead cold, soak the bolts in PB blaster. Try to remove. If not, try heating the stud, then spray it with water. The thermal shock might break it loose. It's pretty common to break these though, so don't feel too bad.
Old Oct 22, 2006 | 05:36 PM
If it leaks, it's because the bolts are loose.
Just tighten them up and see what happens.
Old Oct 22, 2006 | 06:04 PM
Engine: L05's
Its deffinately the manifold, I can put my finger over it and feel the leak. Its really common to break these so I was wondering what tips anyone had that might keep me from doing so. I will obviously try to torque it down, but would like to know if I should heat it up first or what.
Maybe I could start the car and get it to operating temp then try... or would I be better off with a tourch?
Old Oct 22, 2006 | 09:46 PM
What happens when you tighten the bolts?
Go find that out, and if it's not adequate, then come back looking for what to do next.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
