Well, no spark!!!
Old Oct 22, 2006 | 06:13 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Well, no spark!!!
OK, a year or so ago I started a thread asking that if I removed the wiring harness to/from the ECM/sensors would the engine still run since I have a stand-alone 70's HEI and Holley carb. The general consensus was "Yes it would". Well I removed it all from the engine bay and now I have no spark.
The wiring harness that comes through the firewall from the dash is the one that has the pink and white distributor wires in it so I do not understand why it won't start since all that is still hooked up.
This has me puzzled. Any ideas?
Old Oct 22, 2006 | 08:30 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Anybody?
Old Oct 22, 2006 | 11:09 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Removing the harness would cut off your ignition switch from power. Which would not let power to your starter or some fuses.
Old Oct 23, 2006 | 07:44 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I didn't remove the main harness, just the harness from the ecm to the sensors. The starter works and so do all of the accessories.
I think I am just going to hook up a new wire (with ballast resistor) from the fuse block that is switched from the ignition switch and be done with it.
Old Oct 23, 2006 | 09:59 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I had to do that with my carbed 355.
Old Oct 23, 2006 | 10:02 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Where did you end up getting the power from (on the fuse block that is) and did your guage cluster still work?
Old Oct 23, 2006 | 10:39 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
There is quite a few constant powers on the fuse block like hazard's or tail lights, etc... tap into one of those. however, you will want a wire that is hot when it is selected to be with the ignition right? For that I started out with a push button starter. then after I got bored of it, I tapped into the pink and black wire from the firewall.
My gauges worked. Except the tach and speedo, but I had a mech speedo and aftermarket tach. Due to the V6 to V8 Swap.
Old Oct 23, 2006 | 12:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
no resistor needed on an HEI, and i would imagine to check for 12V+ from the pink wire first, and if not then i'd check for blown fuses.
Old Oct 26, 2006 | 02:44 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Well I figured it out, I am a dummazz. The plug on the distributor cap was not plugged in all the way.
Runs now, even with the ecm harness unplugged, just as all said it would.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
