Installing Rod Caps Outside Motor
Old Oct 24, 2006 | 10:42 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I don't have a rod vise and need to install the caps to check the clearance. Can I use my bench vise with some padding? They are Eagle 4340 HBeams
Old Oct 24, 2006 | 10:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I used my vise without padding. Just grip softly. I don't recommend this.
If you have some wood or aluminum flat stock, that makes excellent padding. Or some rubber, like old bushings, and old air dam, etc etc.
Old Oct 24, 2006 | 11:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Soft jaws in a bench vise work.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
BBSDesigns
Aug 11, 2015 07:39 PM
