My camaro won't start..
Old Oct 26, 2006 | 05:25 PM
91WhiteCamaro's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Funny that the tagline in this section is "your camaro's engine won't start?" because that is exactly whats wrong with mine. well i wish i knew more to say, but when i put the key into the ignition, and turn it all the way, nothing happens, my fan turns on (since its hotwired) everything is normal, the radio will come on, and when i turn it, the little engine light comes on, but thats it. also, when I go to turn the key the other way, as if to turn the car off and pull the key out, the ignition sticks at the spot where the radio comes on. im sorry if this is a little confusing, but thats the only way i can explain this dilemma. any and all input is much appreciated
Old Oct 27, 2006 | 07:55 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Have you tried jumping the car to get it started?
Old Oct 27, 2006 | 10:26 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
The car was running before?....
Old Nov 8, 2006 | 07:22 PM
LemurRS92's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
I have similar problems that come and go i think its the ignition switch itself
Old Nov 9, 2006 | 09:24 AM
Quicc Silver Z's Avatar
Car: 82 Indy Pace Z28
Engine: 383 Stroker
Or starter wire could be loose or starter it-self
Old Nov 9, 2006 | 03:26 PM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Transmission: 700R/700R
Axle/Gears: 3.42 Posi/3.27 Posi
try this put your key in the ignition pull the fuse for the ECM and let it set a while with the key in it probably about 10 min or so put your fuse back in it should start up with no problems.
camaro11j
Sep 19, 2018 08:49 AM
Derick15
Sep 17, 2016 05:28 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
