91 RS Engine problems...help me figure out where to start!
Old Oct 26, 2006 | 08:23 PM
97ramsst's Avatar
Car: 2008 F350 SuperDuty & few F-Bodies
Engine: Twin Turbo 6.4L Power Stroke
Transmission: Yeah, it has one.
Axle/Gears: Yeah, some of those too.
I just bought a 91 RS with a newly built 305 in it and I need some help. The engine will crank up easily but when you go to pull off it will backfire back through the TB and die. IF you can get it to actually pull off it will spit and sputter very bad and cut off. A little back ground on the motor...its the stock 305 block bored 30 over...balanced and blue printed...stock cam specs...double hump heads (the stock intake has been "modified" to fit them )...MSD distributer, wire and coil. I basicaly stole the car but would like to get the engine running right before I pull it out...any ideas where to start? Does it sound like a computer/TBI problem or timing problem? I am thinking an intake and carb might solve the problem...any input would be greatly apprecaited though.
Old Oct 27, 2006 | 09:47 AM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
with the bcak fire like that sounds like you need to check the timing as
you might be 180* out of time. start at that and check that all the wires are on the correct locations and should fire up and run for you.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
