this is just frustrating
Old Oct 29, 2006 | 04:22 PM
white87iroc's Avatar
I am hoping that someone can help me on this.
I bought my car pretty recently and it wasn't having any problems. motor pulled like an ox and the trany shifted just fine. However about a month later, it is sluggish and now it just feels like i am getting about half of the power out of it. I cleaned the MAF and K&N filters. It is a 305 TPI. I just don't even know where to begin looking to trouble shoot. I was hoping you guys would know where a good point of entry, if it were, would be. The other thing is that it is fairly sluggish on the throttle. It is like a hesitation then a pull from the motor. The engine just doesn't sound as powerfull at idle or otherwise, and it performs like a smaller engine. I hope that helps as far as description because that is about all I've got.
Anything would be awesome.
Old Oct 29, 2006 | 04:51 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Start with Basics
Some things we need to know:
State of tune - anything done to it recently? Everything in good shape (plugs, wires, cap & rotor)? Any codes stored?
Check fuel pressure
Check air filter
Check for plugged exhaust
Fuel filter changed recently?
Check Throttle Position Switch (TPS)
Let us know,
Corky
Old Oct 29, 2006 | 05:53 PM
tune as in tune up? I don't know... I need to do that soon I'd imagine. Fluids and related filters all changed.
Cleaned air filter and MAF
I don't know about the TPS what should I check for that?
And I don't think there is a clogged exhaust.
Old Oct 30, 2006 | 05:21 AM
Corky's Avatar
Engine: 2.8L
Yes, I meant tune-up. Make sure everything is in tip top condition.
For TPS see Tech Articles from the home page. WHat you are looking for on the TPS is on a digital VOM, smooth voltage change as you open the throttle. Jumpy voltage readings will equate to stumble.
No codes stored?
Corky
Old Oct 30, 2006 | 04:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
fuel filter was first and foremost on my list.
Plugged exhaust would be next.
Check tranny fluid level too
also check your plugs, perhaps replace. Maybe test spark quality.
Old Oct 30, 2006 | 07:34 PM
awesome... thanks guys, i'll check those out in the next couple of days.
gta892000
Aug 11, 2019 11:16 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
