Valve/Piston Clearance Question
Old Nov 1, 2006 | 03:35 PM
km7152's Avatar
Car: 1991 Camaro Rs
With flat top 2 valve relief pistons (+5cc), on a 383, .030 block, standard head gasket, 64cc aluminum heads, whats the safest lift cam I can run without risking valve/piston interference? Basically, after a lot of reading and questions ive narrowed it down to the Eagle balance/forged 383 bottom end, and the holley systemax engine kit. (aluminum heads, dual plane intake, decent lunati cam), the advertised lift with 1.5 ratio rockers in summit is 490/490, and jegs is 488/510, not sure why they are different but anyway, that cam seems a little small for my motor so is it safe to run 1.6 rockers? about where would that put my lift? I know, a lot of questions... any help is appreciated
Kevin
Old Nov 1, 2006 | 04:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You can run huge amounts of cam before valve to piston clearance is encountered. Use putty and double check before firing up the motor.
I'm talking like .650"+ lift.
What exact cam is that?
Yea, might be a bit small.
Old Nov 1, 2006 | 04:54 PM
ede's Avatar
ede
since max valve lift usually doesn't occur when the piston is at TDC your valve timing comes into play as well as the hard numbers. however it doesn't really become much of an issue untill you get into the .600 plus lift range and .65 is more likely a ghood number to start to worry about it.
Old Nov 2, 2006 | 04:37 PM
km7152's Avatar
Car: 1991 Camaro Rs
Awesome, that gets rid of that worry in the back of my mind. Now I like the systemax kit but still thiinking its a little to small of a cam, 490/490 so what if i went with 1.6 rockers? Or would i be better looking into something else?
Old Nov 2, 2006 | 04:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Got a link to the whole package? Or feel like listing off detailed specs for it all?
How about the cam specs in particular, lift is just a tiny slice of info on it.
Old Nov 2, 2006 | 04:50 PM
km7152's Avatar
Car: 1991 Camaro Rs
Holley SysteMAX II Street Engine Systems for Small Chevy: HLY-300-503-1 - summitracing.com
235/240 duration at .050 490/490 lift and 112 duration
Old Nov 2, 2006 | 05:19 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm runnining identical pistons, 383, eagle kit and 64 cc heads. My cam is 560* lift with 1.6 RR's Your 490 is nothign to be concerned with even if going with 1.6's
Old Nov 2, 2006 | 05:30 PM
km7152's Avatar
Car: 1991 Camaro Rs
Awesome, so valve clearance is definitely not an issue...i guess im gonna have to do a lot more research and piece together a top end, none of the packages seem to suit me....any suggestions?
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
lt1z350
Aug 28, 2015 05:57 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
