PLEASE HELP ME 86 Z28 INTAKE BACKFIRE
Old Nov 3, 2006 | 06:36 PM
jakeyz125200226's Avatar
I HAVE AN 86 Z28 5.0L TPI IT HAS NEW HEADS W/ VALVE JOB.NEW MAF SENSOR NEW O2 SENSOR NEW DIST CAP N ROTOR AS WELL AS PLUGS AND WIRES.HAS 45PSI FUEL PRESSURE NEW FUEL FILTER VALVES ARE PROPERLY ADJUSTED. TIMINGS AT 6 BTDC.NO APPARENT VACUME LEAKS. THE ENGINE WILL OCCASIONALY SPUTTER AND BACKFIRE THROUGH INTAKE IM ALSO GETTING A CODE 44 FROM THE ECM WICH MEANS LEAN EXHAUST.I DONT KNOW WHAT ELSE TO CHECK AND IM SICK OF IT PLEASE HELP. COULD THIS BE CAUSED BY LEAKING INJECTORS THANX JAKE
Old Nov 3, 2006 | 08:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
CAN YOU HEAR ME NOW?
Old Nov 4, 2006 | 08:32 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
@Sonix
How to spot an AOL user---> THEY TYPE IN ALL CAPS!
But seriously, run some injector cleaner thru it and change the TPS with the correct calibration procedure.
1992rs/ss
Jan 31, 2025 05:10 PM
deracer
Apr 11, 2016 12:04 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Ducati900ss
Sep 2, 2015 09:05 AM
dyeager535
Aug 28, 2015 08:10 AM
