Cam Size
Old Nov 6, 2006 | 06:04 PM
beaches91's Avatar
Car: 1991 Camaro RS
Engine: Crate 350, Super charged, 650 CFM
Axle/Gears: Eaton Posi 4.10
Cam Size
Ok I have a 350 Supercharged, What size cam do you guys suggest?
Old Nov 6, 2006 | 07:12 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
I would go with something with at least an .852 lift and about .372 duration on a 118 LSA, also I would run it on a 112 intake centerline and advance it 14-18 degrees. Now thats only if you going to be spraying a 400hp fogger. But first I would more than likley post this in the engine section so everyone can have a go at it......LOL.
Old Nov 7, 2006 | 09:09 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
.852 lift? You crazy. A 350 is not a big block. That thing probably wont even fit it's so big. Not to mention I can't even think of any smallblock heads that would be able to take such lift.
Old Nov 7, 2006 | 10:04 AM
Guest
Guest
Posts: n/a
You can cut the sarcasm in that post with a knife.
Need more info, just 350 and SC doesnt do it. What else? Heads? Intake? Exhaust?
Old Nov 7, 2006 | 03:49 PM
beaches91's Avatar
Car: 1991 Camaro RS
Im changing the heads aswell. Probly going with afr. Exhaust is x pipe. just pipes. Its got 142 wieand blower 700 cfm carb 1.6 roller rockers and with the cam and heads Im doing push rods and lifters. Any suggestion on possibly a whole kit I know would work together?
Old Nov 7, 2006 | 04:28 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Moving this for you...
Old Nov 7, 2006 | 06:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What is your desired RPM band?
What transmission is behind it?
Stall speed on the converter if automatic?
Rear gear ratio?
Which AFR heads do you have planned?
Which year 350 is it?
Do you want to upgrade to retrofit roller if it's not a factory roller?
Do you mind do lash settings on it every oil change? (solid cam?)
What size headers are on the motor?
Keep going, that's not nearly enough info to give anything better than a wild shot in the dark, such as ".852" lift, 317* duration, etc".
Old Nov 7, 2006 | 06:48 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
317 duration....that thing wouldn't start to make any power until you cross the traps by then too late funny thread!
Old Nov 8, 2006 | 05:51 PM
beaches91's Avatar
Car: 1991 Camaro RS
Im not sure wich heads. Any suggestions on those Im kind a a rookie, first build. Headers are hooker comp shorties. Engine is brand new this year. Bought it from JEGS. Trany 700r4 with a b&m shift kit. No stall converter yet. gears are 4.10
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
