Annoying little problems
Old Nov 7, 2006 | 12:26 AM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Well I have a 92 T/A with 99K miles. I recently finished installing edelbrocks hi-flo base and runners, along with their headers, and a cat back exhaust system. Also replaced the injectors with ford injectors and installed a afpr. The idle is off a little. It jumps from 550 to 600 and every once and a while it drops a little lower then that and feels like it's going to die but doesn't. I took off the IAC valve and cleaned it. I tried to adjust it but to no avail. It would not move. Not sure if I was doing it wrong or if it is damaged. How do you tell if the IAC is still good or not? I replaced the cap, rotor, and wires already. Thanks for the help.
pjsparts
Oct 29, 2025 06:39 PM
GTAman
Jul 3, 2024 07:29 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
