help with a ticking noise
Old Nov 12, 2006 | 12:17 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
on my 86 camaro z28, there is ticking noise coming from the rocker arms, i had them adjusted and they still do it, i was wondering if they can be wore out, i was thinking of replace them, with new ones, and i dont know what kind to get, my engine is little work done not much, can someone give me advice on them , and how to replace them and adjust them, and the pushrods while im in there, thanks for all your help
Old Nov 12, 2006 | 12:34 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
whats the differents with this one, this is the one i have on my car
ahd this part below
Old Nov 12, 2006 | 03:47 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i looked around this board and found nothing at all, and i guess no one wantes to help
Old Nov 12, 2006 | 05:00 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Is it a loud tapping noise like when you back it off the rocker arm nut, or kind of like a sewing machine? Also, do you have flat tappet or roller lifters?
Old Nov 12, 2006 | 05:06 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
flat tappet
it sounds like a tapping noise, at idle i cant hear it , when i press the gas it gets louder, the fast i go m the louder it gets
whats the different with tapping and sewing machine sounds
Old Nov 12, 2006 | 05:10 PM
Lo-tec's Avatar
If you back off the rockers they tap loud. Is it the same noise after they're adjusted? Rocker arms shouldn't make noise unless they're fubared. Are you sure it's not an exhaust leak?
Old Nov 12, 2006 | 05:16 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
what do u mean backing off the rockers,
i did think it was an exhaust leak, and my exhaust was leaking, and had the pipes replace, i might be leaking from the headers,
its coming the passenger side it sounds likes the rocker arms. it might be leaking from the headers, the bolts are tight, i will try to replace the gasket and see what happens, i had mechanic adjust the rockers, the rocker are tighten to specs
Old Nov 12, 2006 | 05:22 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
whats fubared mean, and yes the make the same noise after they been adjusted
Old Nov 12, 2006 | 05:30 PM
Lo-tec's Avatar
umm, that's how you adjust them.....by backing of the nut with the engine running, tightening it to zero lash (tapping noise goes away), and then going an extra 1/2 to 1 full turn. My question in a nutshell is when you back them off with it running, does it make the same noise that you're hearing or a different one?
fubared= f'd up beyond all recogintion
Old Nov 12, 2006 | 05:38 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i didnt adjust them, someone else did, but i think they know what they are doing
when u adjust them, with engine running does oil go everywhere
but i cant hear it idle, only when its im pressing the gas
Last edited by jkwild0630; Nov 12, 2006 at 05:39 PM. Reason: Automerged Doublepost
Old Nov 12, 2006 | 05:43 PM
Lo-tec's Avatar
Then I would ask whomever adjusted them if it's a valvetrain noise. WAG is it's a header leak. Good luck.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
