need help hooking up tach to distributorless system
Old Nov 13, 2006 | 09:25 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
how do i go about hooking up a tachometer to a distributorless system? the car has a crank sensor of course and i cam position sensor...i dont know if that matters. im reading something about hooking one of the wires to the negative terminal on the coil. how do i find the negative terminal? i know u guys are experts so this is the first place i came to for help. i dont care if i sound like a dimwit either
thanks!!
Old Nov 15, 2006 | 07:17 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
what car is it for? most cars have a "tach out" wire.
Old Nov 15, 2006 | 08:54 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
most cars have a "tach signal" wire coming from either the ignition system, or the PCM...
Old Nov 15, 2006 | 12:33 PM
rwdtech's Avatar
there is an "engine speed signal" wire that comes out of pin #42 on the PCM connector. could this be a satisfactory place to hook up the tach signal wire too? will an engine speed speed signal from a PCM send too many pulses?
it is for an OBDII equipped 4 cylinder car with a dual coil pack system.
Old Nov 15, 2006 | 01:35 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
hook it up and see what happens. you must have a diagram right? if thats all it says i would guess thats the right one.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
