removing the rear end to get to the gas tank
Car: 1989 IROC Z
Engine: TPI 350
Transmission: 700R-4
When you are removing the rear end do you just take the shocks off from the exle or is it easier to do it from the top (behind the seat). Or is there a easier way to get the gas tank out?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Put car in air high and stable(triple check)
If your call falls on you for shoddy jacks or bad placement on your behalf I dont say "How sad!", I will point and laugh.
Now:
Remove rear wheels.
unbolt exhaust.
Unbolt lower shock bolts.
lower rear end with jack
Remove exhaust intact over pass wheel :-)
remove all heat shielding in way of gas tank
unbolt fuel lines up to the front of the car.
lower rear end as far as it will go(brake line, watch out for it)
unbolt filler neck surround.
unbolt tank and twist towards rear of car as u drop the far corner of it.
swap pump and reverse.
later
Jeremy
Should take 3-4 hours if your mechanically inclined
Now:
Remove rear wheels.
unbolt exhaust.
later
Jeremy
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Here is a quick explanation
EDIT: Been beaten to the punch
Car: 1989 IROC Z
Engine: TPI 350
Now the fuel hoses are the ones on the driver side right, there is like 4 hoses that you use a flat screwdriver to take them off right. And the one connection in the middle of the car.
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Just pulled mine today. In addition to what 3.8 said above, remove end-links on the anti-sway bar if equipped (good time to replace them!). If the rear then drops enough that the springs fall out, you probably have enough room. I marked (indexed) where the end of the springs were on the bottom perch before they fell out.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That's allot of work.
There is an easy way. Though GM didn't think of this till 00 and put in a hole so you could do this, then they cancled the line?
Jap cars are smart and do this by adding a hole factory.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Should mention some folks will say these cars are so flimsy it will fall apart if you cut that metal back there. And others will say it so strong back there it will never move "your RSTB does nothing".
Myself I have done this, there was no side effects but I also didn't butcher it as bad. But I also installed a rear shock tower brace. Again some say it does notihng, other think my car will fall apart with out it.
I found no difference after cutting the hole but did notice it a bit stiffer after adding the RSTB. I used steel braided fuel line and double clamps on each end for the fuel lines. Steel braided can turn sharp n not kink. Reg rubber will work but you may need to stick a spare hose clamp in the middle of the bend to make it stay round, not kink.
I use some of the same hose n clamps for my fuel filter. I just get the same large one but with nipple ends, not threaded.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You have to remove the exhaust - disconnect it from the cat, and pull it out over the axle - leaving your muffler in tact - that way you don't have to readjust your muffler pipes.
To do this, I found the car must be jacked and on stands at least 18 inches up off ground. Then the entire intermediate pipe with muffler and tailpipes attached will come out over the rear axle.
I just took my tank off last week. Wasn't able to pull the exhaust pipe/muffler completely out after disconnecting in from the cat because of the shape of the pipe,.. I just raised the body far enough to work the tank out. Would have been nice if the freakin filler neck was disconnectable. I also put a long stick in the filler neck from the outside to kind of giude it out with force. If your car is anything like mine, and you took the track bar / brace off, then when you're putting it back together, remember to put the exhaust pipe above the damn track bar before you re-install the track bar! This really pissed me off when I realized I forgot!
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
I;m in the process fo doing this job right now. I got the exhaust out (had to cut), removed the panhard bars, loosened the tank only to look and see a hole was already cut in the past. That pissed me off!
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Easy job. I can have the gas tank and rear end out of a thirdgen in less than 40 miutes, working by myself.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
