L98 ???
Old Nov 16, 2006 | 10:26 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
L98 ???
Ive allways herd that the L98 was a low tour engine.Well i swaped out my tpi for a 600 cfm and a tourker intake well i should't do it but it pulls way past 6500 ,its deffently a l98 but not the orig engine that was in my car are they spouse to pull that much did the carb make that much of a diffrence.and why
Old Nov 18, 2006 | 12:25 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What?
I don't follow - you definately have an L98, but it's got more power than you think?
ok, an L98, to be perfectly correct, has a TPI setup on top. Once you remove that, it is no longer an L98, and it becomes "a chevy 350".
You're right, 600cfm and a torker intake (ugh, is this the torker 2, or...?), shouldn't pull that high with stock cam and valvetrain. The TPI setup holds it power band below 5000rpm, but the stock cam and valvetrain probably hold it below 5500RPM. You might be able to force it up to 6500RPM, but it's not "pulling". I mean, it'd make it down the 1/4 faster if you shifted it at 5000RPM probably.
Factory tachs are notoriously inaccurate, you can always grab a cheap 2" one and jerry rig it up to check the accuracy.
Old Nov 18, 2006 | 12:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i accidently took my L98 with TPI on it to near 6300 in first gear...it sure got there in a hurry. but in all reality, it wasnt pulling.
stock cam and heads are good for 5000-5200rpms but thats about it. carb and intake manifold shouldnt make it pull after 6000 rpms. it will definately be stronger above 4000rpms all the way to 5000, but its not "pulling" past 6500. the cam isnt big enough to flow air that high up.
Old Nov 18, 2006 | 12:31 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
GM setup the 350 TBI 9C1s to shift at 5,500 RPM at WOT. They have the L98 cam but swirl port heads on them.
Old Nov 18, 2006 | 09:05 PM
RandyZ's Avatar
maybe
Maybe your right i plan on changing the tach out for a aftermarket one .I don't want anyone to think im trying to talk out my As$ maybe the tach wronge. This is my first 350.I want to put the TPI back on but don't know I think the carbs better
Old Nov 19, 2006 | 03:44 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
The carbuerator is naturally going to be the
better performer on a "un-touched" L98 at first..
Or least it seems that why.
If you like zippin everywhere at WOT, by
all means keep the carb on there.. But TPI
is vastly superior in my eyes
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
