engine turns, won't start help!!!!
Old Nov 24, 2006 | 08:26 PM
99transamgirl's Avatar
Car: 84, 99 Trans Am
Engine: 305 G, LS1
to start with, the car ran great until about a month ago.it's a 84 305 trans am. i always check the oil. i knew that coolant was leaking out of the top of the manifold just a little. went out one day to start it and i checked oil it had coolant in it.i shut it off right then. got a kit and replaced valve cover gaskets and intake gasket. there was signs of it leaking into the block from the top. i put everything back the same way it came off. i marked the rotor, distributor but when i put it back in it wouldn't go in the same way. it moved to the left by about an inch. the car won't start. it turns over but won't start. it has new plugs, wires, distributor car, rotor cap. fuel pump is fairly new. it is putting gas into the carb. i dont have any money to put out buying special tools to check compression etc. it was spitting out gas out the top of the carb. the check engine light and choke light doesn't come on anymore now. any clues? PLEEEEASE HELP
Old Nov 24, 2006 | 08:40 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
check the firing order?
18436572
Old Nov 25, 2006 | 11:05 AM
kenf729's Avatar
Car: 1989 Camaro RS, 355, holley 650dp
Engine: flow master headers, 3" exhaust
Axle/Gears: stock
Find TDC, take dist cap off and see where the rotor is pointing, that will be #1, check your wires, going around the cap clockwise 1=1, 2=8, and so on firing order 18436572.
Old Dec 9, 2006 | 05:58 PM
Engine: 305 G, LS1
i got it tdc and moved plug wires all over one spot. now runs but sounds a little loud/ rough. thanks for help
Old Dec 9, 2006 | 06:28 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The timing has to be set, no way around that, unless you like it running rough.
Old Dec 11, 2006 | 09:20 PM
Engine: 305 G, LS1
any clue what the loud clicking sound is that i hear. i don't hear it when i listen to the valve covers but i hear it and feel it by the back of the manifold. the two hoses that connect to it in front of the dist. is where i hear it the most. i can hold the hoses and feel the pulse or clicking as i hear the sounds. it's VERY loud. I also hear it from the carb as it warms up. it's so loud i can't stand to be by it. the car rruns very rough and dies shortly after being put into gear.i;m starting to think something is wrong with the lifters or pushrods. i hope i haven't damaged anything too bad. any clues? could the timing chain be a problem?
Last edited by 99transamgirl; Dec 15, 2006 at 10:43 PM. Reason: change in sound of engine
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
