Your opinion
Your opinion
Ok decided to go carbed i want to keep it stock and only change ( carb electric choke,intake,distributor msd?? vac advance??.fuel regulator).
what is the best way to go to keep it smooth idle .
i am not lookin to race the car its my daily driver. I have been hearing all different things from all different people it gets confusing is there one baisic setup that is not to expensive
I think the car has enough power for what i am using it for .so if i could keep the same power and a smoother (regular idle)...oh and have it start first time in the morning ...I would be happy
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
With a new four barrel, I would strongly suggest a new intake, mostly for lighter weight, better heat dispersion, and a bit more power for the same economy. Another great upgrade would be a MSD style ignition, I prefer the accel 300+ for the simple install, and the integrated adjustable rev limiter for the same cost as a MSD 6A box. MSD will give you better economy, faster starts, and a bit more power. Another thing you might consider is a distributor, although you would most likely have to get one with a new ign. box. What kind of carb are you looking for? Hope this helps,
Well what i am really asking is suggestions for a daily driver
what carb would be best
what dist is best
what intake
and fuel regulator
for a smooth running (idleing) daily driver. But no loss of power
and not to much bank needed...lol
what dist is best
what intake
and fuel regulator
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what kind of idling issues? what do you have and whats the problem? going carb for all out performance makes sense if your tryin to save money vs. injection which is much more expensive but if its an idle issue why not try to fix the problem? Give us some details and maybe we can help! There are many knowledgeable members here and I doubt you have an origional problem nobodys ever delt with before.
here goes
new iac
new tps set at .54
minumum idle set 600 in drive
timming 6 deg before
plug timing advance wire back in after setting everything
idle jumps to 800 drive 1300 park and vibrating
unplug timming wire 600 drive 800 park skips like hell.
no vacume leaks thats been checked
morning start is bad idles at 500 real rough for 5 minutes then the hampster under the hood flips the switch and it idles like i posted above.
no hesitation on acceleration or driving it'll smoke the tires from dead stop all the way threw 2nd gear..Pleanty of power for me to get to work lol
new plugs
wires
cap
rotar
fuel filter
pcv
air
smog pump disconnected
no cat
new flowmaster
complete rebuilt front end
car is like new inside and out
117,000 miles
wanna BUY it ............................lol
i'll have pictures soon
it is a one owner southern car. And i would like to keep it if it would just idle better
new iac
new tps set at .54
new plugs
wires
cap
rotar
fuel filter
pcv
air
no cat
new flowmaster
117,000 miles
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
skinny z
Oct 5, 2015 06:23 PM
