REALLY weird starting problem.
Old Dec 8, 2006 | 11:00 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
So im having some very strange problems when I try to start my car.
Recently, when I go to start my car, the starter would click, as if there wasnt enough battery. I would wait maybe 5 seconds and all of a sudden it would start cranking and start.
Now that its getting terribly cold outside, when I go to start my car, if I turn the key all the way foward all my power is drained, my lights dim severley and the starter wont even attempt to engage. If I just keep trying over and over *eventually 5-10 minutes later* then it will all of a sudden, the stater will start engaging and it will start.
Also, my tachometer goes ALL the way to its ends if the car wont start, and if I just leave the key foward, then the tach will jump back, hesitate, jump foward, hesitate, jump back, hesitate, then jump foward, doing that over and over.
The first day that this started happening, when I was driving, my stereo would shut off, my voltage gauge would drop ALL the way to 0.
My voltage gauge while driving is actually higher than normal, 3/4ths of its way through the meter.
Ive had electronic gremlins already, and ive posted my problems in the electronics part of the forum, it was stated that its my alternator that is at fault. I havent had the chance to replace my alternator yet but would a failing alternator cause these issues?
Old Dec 8, 2006 | 11:40 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Check your grounds yet? Also may be a weak starter. I am having the same problem just havent had time to get around to it. I would hit the push button starter and the starter would just click, may do it several times or may just kick over. Was using a 650 cca battery, put in a 800 cca battery and it stopped for awhile, til it got cold. Give ya something to start with. On a side note the starter is less than a year old.
Old Dec 8, 2006 | 11:52 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Did you get your starter from autozone? My starter is less than a year old also.
Old Dec 9, 2006 | 01:29 PM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
I had the same problem last year. (except for radio problem)
Replaced the starter with an auto zone one and the clicking was still there. After theat i found a loose engine ground, tightened it and it STILL did it. This winter I am going to check all the power wires for shorts going to the starter. Maybe you should do the same
Old Dec 9, 2006 | 03:11 PM
brp88gta's Avatar
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
i had the same problem with my trans am and it turned out to be a really really stupid little thing. my ground wire to the batter was snug but wasnt real tight. make sure your battery termanals are real tight. that was my problem. i had the exact same problems as you guys. my car would not turn over at all then it would crank fine. the battery guage would jump all around too.
Old Dec 9, 2006 | 10:06 PM
Beachmonkey6's Avatar
Car: '88 GTA
Engine: L98 -350TPI
Maybe your battery isnt rated for such low temp as it is outside. Or your battery might just be getting old.
Old Dec 11, 2006 | 12:54 PM
Just throw a bigger battery in it thats what i did.
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
EFR2000
Aug 18, 2015 08:54 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
