starting issue
Old Dec 12, 2006 | 10:09 PM
estone06's Avatar
Car: 1991 Camaro RS
Engine: 350 stroker .40 over 11:1 comp
starting issue
I have a 91 RS with a built 350 from a 1982 Chevy 3/4 ton pickup. I have recently completed the swap. At first, the starter was grinding down on the flywheel, so I bought new flywheel and starter, correct for the make and model of the block. 3970010. When I try to turn the key, no crank. Power is ran to everything, including lights etc... when i get under the car and use a screwdriver on the solenoid it turns over. I have no idea what this can be. All the connections are clean and tight. Does anyone have a clue. ---i have not tried to jump it yet either, and yes there is spark. It is almost as though there is not enough juice to turn the starter, but i have charged the battery, and if that was the case, it would not be able to turn the motor over when shorting the solenoid.
Old Dec 12, 2006 | 11:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Getting the full battery voltage to the solenoid can be an issue. I was losing 2 volts through the ignition switch. I finally put on a remote solenoid to "solve" the problem.
Make sure you have all of the wires hooked up properly. You probably do, since you know which terminals to jump to test it. Check what voltage you are getting at the solenoid.
In my "quest", I also found that a cheapo Autozone solenoid worked better than the "good" NAPA solenoid. So, your new starter may have a solenoid that is more sensitive to low voltage.
Old Dec 13, 2006 | 08:06 AM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Transmission: 700R/700R
Axle/Gears: 3.42 Posi/3.27 Posi
Do you think it could possibly be the vats system causing your no crank problems
Old Dec 13, 2006 | 01:27 PM
estone06's Avatar
Car: 1991 Camaro RS
it is possible that the solenoid is not up to par, I will try to replace that first, and put a new solenoid on the new starter.
hoseman--can you elaborate a bit more on what you mean by vats?
Old Dec 13, 2006 | 03:31 PM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Look at your ignition key there should be a chip in it or its actually a resistor that works with the ecm theres an article on this site about it if your key switch is getting some wear on it the key and the ecm might be loosing sync with one another i have a 92 and mine dose this ocassionaly thought this might be worth looking into.
Old Dec 13, 2006 | 03:47 PM
estone06's Avatar
Car: 1991 Camaro RS
hoseman, ok i know what you are talking about now. However, the block is a 350 in place of the 305 tbi. I have disconnected all of the ecm components. I still have power to dash, headlights etc.. the motor and starter were turning, but the starter was grinding the flywheel, so now i have replaced them both, and this leads to the current problem.
Old Dec 13, 2006 | 04:07 PM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
hmm ok have you got the wire hooked up on the S side of the solonoid thats for the switch or it might just be loose or something.
Old Dec 13, 2006 | 06:55 PM
estone06's Avatar
Car: 1991 Camaro RS
I have a new development now. I went to start it again as a last ditch effort, and when i turn the key I can hear the starter tryign to turn but it doesnt actually turn over. Every single time I was hitting the key, the starter attempted to engage, although it did not continuously turn over, it tried to turn almost as if there is not enough juice going to the starter. My timing is not set yet, but am positive that it should not be a factor at this point. Any ideas anyone? Hoseman?
Old Dec 14, 2006 | 07:20 AM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Try this slow charge your battery all night then try to start it, if that dosent work you might need to shim it
Old Dec 14, 2006 | 07:50 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Did you disconnect the ECM before or after trying to start it the first time, or before installing the new flywheel, and starter?
Is the new motor a carbed 350?
The anti-Theft system is part of the car not the motor, remove the motor and you still have VATS. There are conditions where VATS will allow repeated attempts to start (no signal from the ECM) as long as you have the right key, or the VATS is currently disabled.
Old Dec 14, 2006 | 01:32 PM
estone06's Avatar
Car: 1991 Camaro RS
that is some great info. I disconnected the ecm when I made the engine swap. I dont feel that this is a vats issue. in my mind it would be more along the lines of th eactual solenoid or the coil inside of my distributor. it just seems as though it is not getting enough juice. I will play with it over the weekend and see what I can come up with. keep the ideas and theories coming though guys.
Old Dec 16, 2006 | 05:09 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
from what I've read, the VATS module is separate from the ECM. you may have removed or disconnected the ECM, but you might still have the VATS wired up to your ignition key circuit, inadvertently.
not sure on the intricacies, but it's conceivable that if the VATS isn't getting the right signal from the now-missing ECM... not allowing a start?
Old Dec 16, 2006 | 07:30 PM
estone06's Avatar
Car: 1991 Camaro RS
okay, so i had a bad solenoid, replaced it and got another brand new starter, everything was turning over earlier today just fine. I went to set the timing tonight, and now the starter is doing the exact same thing, except when i had the camaro jumped to another car. then it turned over a few times then as well. came back to it a few hours later, and now we have the same problem. the starter is not kicking out, i can hear one metallic click on the starter and that is it each time i turn the key.
Old Dec 17, 2006 | 12:31 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Assuming jumpering the terminals with a screwdriver makes it turn.
Try bypassing the fuseable links and associated wiring to the starter's B-terminal by running a wire directly from the battery positive to the B-terminal.
Use one cable from a cheap pair of booster cables and put a ring terminal connector on one end. If there's not enough room on the starter B-terminal post for another ring terminal, remove only the one coming from the battery positive. Clamp the other end of the booster cable to the battery positive.
Old Dec 17, 2006 | 01:29 AM
estone06's Avatar
Car: 1991 Camaro RS
garcia, im not sure that I follow you and what you are suggesting......
Old Dec 17, 2006 | 10:21 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Correct me if I'm wrong;
When you shorted across the terminals on the prevoius starter it turned as it should, but wouldn't with the key.
You've changed out the starter/solenoid since then, and it turned, and now it's back to square one.
If the battery has the cranking amps to turn the starter then there's a problem with getting the current to starter e.g. wiring.
At this point you've eliminated the starter/solenoid and battery unless some how you're damaging them, so there's nothing left, but the wiring. Specifically the positive battery cable.
Wiring can corrode internally and cause the resistance to increase and reducing the amount of current the wire(s) can handle.
Assuming the engine block is properly grounded, there is only one wire than can supply the current and that's the positive battery cable (4g,) if it's corroded internally it will not be able to carry the current.
Basically what I'm saying is replace the battery cable, or bypass it as a test.
Of course the problem could also be on the ignition side, but bypassing the battery cable will isolate the problem to the ignition side.
When I had this problem the first thing I did was replace the positive battery cable with one from a Dealer because parts store don't carry the original, which has the alternator wire already attached, and yes it did solve my problem.
Old Dec 21, 2006 | 10:53 PM
estone06's Avatar
Car: 1991 Camaro RS
Well, make a long story short fellas, I replaced the distributor, cap and rotor. Started immediately. Now I am swapping out my old oil sending unit that came off of the block and using the 91 305 oil sending unit. There is a bit of oil escaping from the hole however. I am having a rough time tracking down a few brass parts, but in the morning, I will go to a plumbing store and im sure ill find it there. thanks for all the help fellas.
Old Dec 21, 2006 | 11:43 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
So what happen to the starter problem?
You can't solve a starter problem by replacing the cap & rotor.
Old Dec 22, 2006 | 09:48 AM
estone06's Avatar
Car: 1991 Camaro RS
Well, after swapping the starter and solenoid a total of 9 times in one day, I said "F" AutoZone and went to Oreilly. Problem solved there. It wasnt the Vats, it wasnt a loose ground or connection. It was just 9 pieces of junk from China.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
