350TPI running rough
Old Dec 15, 2006 | 12:26 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
i had this problem for months. when i start the car i have to stay on the gas so it will not die. then when i start driving the car its ok when the engine is cold and the RPM is at 1000 or higher. But when the engine is at warm and at operating temp and the RPM is a 500 it want's to die. I always put it in neutral to stop it from stalling out. what do you think it is. can the timeing be off?
Old Dec 15, 2006 | 04:17 PM
1320-camaro-383's Avatar
Car: 91 camaro
Engine: 383 demon 750 rpm heads 150 shot no
Transmission: bto 700r4 stage 3
Axle/Gears: currie 9" 4:10 true track
Is your check engine light on?Has it had a tune up latelly?Have you replaced your tps sensor just before you started having this trouble?
Old Dec 15, 2006 | 08:56 PM
Car: 91 formula
the car was tuned up a month back. The check engine light comes on at highway speeds only. But goes away when i turn the car off and will not come on. and i did not touch the TPS.
Old Dec 15, 2006 | 09:19 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Hmm Sounds like a Egr Valve malfunction to me
Extremely close to dieing or stalls out at idle? ( Egr on idle makes the engine stall)
Old Dec 15, 2006 | 09:20 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
Check the code for your check engine light.It sounds like an EGR problem.
customblackbird
Aug 15, 2021 10:16 PM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
