IROC-Z stalls randomly! Help!!!
Old Dec 16, 2006 | 02:26 PM
8989's Avatar
Car: 89 Camaro IROCZ
Engine: stock 350
Transmission: automatic
Just got off work and I'm sitting at a stop light. The light turns green so I go. So at about 20 mph the engine felt like it stopped pulling for a second kinda felt like a rev limiter. Felt like I let off the gas for a second and got back on. 10 minutes later the car stalls. I crank it again and it drives the rest of the 20 minutes back home without a problem. What could be the issue on this formerly reliable car?
ps: this car is 100% stock and from what I see there are no codes. Motor has 197k miles. Fuel rail holds 40 psi of fuel pressure from what I see on the gauge. Cap, rotor and ICM were changed 2 years ago.
Old Dec 16, 2006 | 09:31 PM
8989's Avatar
Engine: stock 350
ttt anyone?
Old Dec 16, 2006 | 09:33 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Originally Posted by 8989
Cap, rotor were changed 2 years ago.
Well thats probably your problem.
Try that first along with new plugs and possibly wires.
They can do wonders to an engine.
Old Dec 16, 2006 | 09:44 PM
8989's Avatar
Engine: stock 350
How often are you supposed to change the cap, rotor, and ICM for preventative maintenance???
Old Dec 16, 2006 | 10:01 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Axle/Gears: Ford 9"
I do it every time i change my spark plugs. The contacts in the cap wear down pretty quick, especially when using MSD boxes.
Old Dec 17, 2006 | 06:42 PM
8989's Avatar
Engine: stock 350
So if my ignition is stock how many miles before it needs to be checked for wear and tear?
What other problems would cause sudden stalling? I still have no codes even if the car stalled out just awhile ago at random...
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Luigytico09
Oct 1, 2015 08:46 AM
ndndndnd
Sep 28, 2015 08:00 AM
