Setting Ignition Timing
Old Dec 17, 2006 | 01:17 PM
87transamTtop's Avatar
Car: 1987 Trans Am
Engine: LG4 (I desire a 383)
Axle/Gears: Stock?? 1.0? :)
The label under the hood of my 5.0 4bbl LG4 says that for an automatic it should be 0* @500 (D)
My question is on the (D) part. Do I have someone stand on the brake or jack the car up? Also, why does it need to be in drive anyway?
Old Dec 17, 2006 | 01:23 PM
Damon's Avatar
It shouldn't matter if it's in gear or not. Once that timing connector behind the distributor it disconnected all computer supplied timing is eliminated completely regardless of gear or RPM.
I believe you are looking at 2 different specs. One for timing and one for recommended idle speed once you're done setting the timing (500 in drive).
Old Dec 17, 2006 | 01:38 PM
Car: 1987 Trans Am
That makes much more sense, thank you
One other thing, how many degrees is each notch on the mark? Are they 2* each?
Old Dec 17, 2006 | 06:23 PM
Damon's Avatar
The bottom of the big V is 0*. The tip of the next V CCW (to the left as viewed from the front of the motor) is 4* BTDC. The bottom of the next V is 6*. The next tip is 8* and so on, 2* at a time, trough to tip.
Do a search and you'll find a picture of the markings for the timing tab.
Only 0-4* is a little odd becuase they put 0* at the bottom of a deep V. From 4* BTDC on up it's 2* at a time from every tip to every trough.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
