Head problems
Old Dec 19, 2006 | 11:02 AM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Head problems
the drivers side of my engines spark plugs have a hole bunch of oil and ash deposits on it and ive had no engine power since ive had the car does anyone no what this is..
Old Dec 19, 2006 | 01:41 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Leaking valve cover gasket on that side.
Old Dec 19, 2006 | 07:22 PM
xgtharo86x's Avatar
Car: 86' Trans am
there new and its on the inside not the outside i was thinking its the valve seals cuz it dont smoke
Old Dec 19, 2006 | 07:26 PM
F-BIRD'88's Avatar
Believe it or not but the oil from a leaky valve cover gasket can migrate down onto the spark plugs and get past the threads into the motor. I'd also look at the intake manifold gasket.
Old Dec 19, 2006 | 09:52 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Hey F-Bird, i just want to confirm my thought with you.
My car drivers side center 2 plugs (#3 and #5) both get covered in oil after about 700-1000 miles eventually causing a misfire on those 2, while all the other plugs are fine. My valve cover gaskets do not leak at all, infact the engine is very very clean on the outside.
I do see a SLIGHT amount of oil where the intake touches the head. Chances are the gasket in this area is bad and is causing the problem, is this correct? Im putting on my HSR soon, so i guess i will find out soon enough.
Old Dec 19, 2006 | 10:07 PM
xgtharo86x's Avatar
Car: 86' Trans am
haha those are my 2 plugs 2 looks like the same prob wuts a HSR
Old Dec 19, 2006 | 10:10 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Axle/Gears: Ford 9"
HSR is Holley Stealth Ram, its an Aftermarket Intake manifold.
Old Dec 19, 2006 | 10:12 PM
xgtharo86x's Avatar
Car: 86' Trans am
ooo let me no if that was the prob
Old Dec 28, 2006 | 12:54 PM
xgtharo86x's Avatar
Car: 86' Trans am
ttt
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
