vaccum
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
vaccum
how many vaccum inches of mercury are you supposed to have on a tbi 350. I took a reading off of the tbi in the front vaccum line and got about 21. is this right?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Your just idling in the driveway in neutral eh? That's ballpark.
Car: 1989 RS Camaro
yea just sitting there. i was using the vaccum to set my timing. I was always under the impression that it was supposed to be around 15 or so.
Car: 1983 G20 Chevy
Transmission: 4L60
20-23 in/hg is about right. Higher compression ratio typically gives higher vacuum readings, smaller cam has higher readings, roller cam increases reading, and reducing internal friction helps, as does gapless piston rings and good valve seal.
My old 312 with the tiny roller cam in it would run at 22-23 in/hg @ 650 RPM. At a steady 2,500 rpm it was pulling down about 24 in/hg unloaded.
My ZZ4 cammed 350 pulls about 18 in/hg unloaded.
zupmanZ28
Mar 13, 2001 05:07 PM
