Wont start!
Old Dec 27, 2006 | 01:02 AM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Wont start!
Well I bought my car a few months ago in a non running condition. The carb was missing along with a battery and a few other parts. Once I got all new stuff I went to go turn it over and the starter was grinding, so I went out and bought a new reman. starter. I installed it with all the shims that the other one had and went to go fire it up. It ran for a little bit(ran outta gas). Then I went to go start it again and it just grinds not like the starter grinding but like the starter and the flywheel can someone help me? I even tried taking the shims out but to no avail. Right now I have one shim in but I havent tried starting it. Am I better off getting it professionally fixed or doing it myself and experimenting with shims?
Old Dec 27, 2006 | 09:42 AM
Vader's Avatar
What year is the block (Casting number)? The next time you have the starter removed, take a close look at the outboard starter mounting hole. Does the casting appear damaged in that area? Is there very little material around the hole?
Old Dec 31, 2006 | 01:54 PM
Engine: 406sbc
Transmission: TH400
The starter holes are fine. I'm not sure on the engine numbers. I tried looking everywhere on the back of the block for them and I couldnt find them.
Old Dec 31, 2006 | 02:42 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
You may want to check the condition of the teeth on your flywheel, could be that when you initially started it the flywheel was in a position where the teeth were good, now it's in a place where they're not? To check this the easy way, manually turn over your engine with a socket on the middle bolt on your crank pulley and use a breaker bar, try intermittently starting it at different positions.
Old Jan 2, 2007 | 09:43 PM
Engine: 406sbc
Transmission: TH400
The teeth on the flywheel look fine but I'm not an expert so I dont know, this mystery has been going on for about 3 months now.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
