Can some one please tell me how this works?
Old Dec 29, 2006 | 12:26 PM
streetassasin's Avatar
Car: 2001 SS
Engine: bolt on LS1
http://www.hawksthirdgenparts.com/in...ROD&ProdID=910
I know I will probably need it since now I have 28'' tires and the 3.73 gears that are going in. But how does it work and where does it go? lol
Old Dec 29, 2006 | 03:53 PM
TABANDIT's Avatar
Car: 1987 Transam
Engine: 1991 350 Bored .030 over
Transmission: TH350 w/stage 2 shift kit
I've got mine part way installed (I burned a wire on the exhaust and don't have the patience (sp?) to fix it right now). There is more info at http://www.dakotadigital.com/index.c...rod/prd126.htm . As far as I understand it, it takes the signal from your transmission and changes it so the speedo reads the correct speed. It has a couple of different options (hence the many plugs) and can be recalibrated as many times as you like, so whenever you change to different tires. All you have to basically do is splice into you speedo wires somewhere along the line and install the unit somewhere in your car (I'm putting mine in the ash tray because I don't use it anyways). One thing to note though, the instuctions may look overwhelming at first, but once you find which option you are going with it it pretty much a piece of cake.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
