clanking sound on accel to sputtering on decel
Old Dec 29, 2006 | 07:31 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
What would cause a clanking sound from the rear of the engine over 2500 rpms to a sputter deleration. The noise is so loud it almost sounds like a nut flying around in the #7 combustion chamber. I poked around with a stethescope and the noise seems the loudest at the rear of the block. I took the valve covers off to check the rockers, rods, and to see if the keepers were still in the spring retainers. What do you guys think? Could this be an exhaust problem? I listened to the collector on the drivers side and it sounds bad as well..
Fanatic1074
Oct 3, 2022 05:57 AM
Lbibb
May 5, 2016 12:00 AM
wanext
Oct 6, 2015 12:18 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
efiguy
Sep 27, 2015 01:30 PM
