If you can answer this....(you're awesome)
Old Jan 1, 2007 | 06:11 AM
Fmandan's Avatar
Car: 1987 Formula 350
Engine: TPI 350
There are two hoses coming off the heater core. The one on the passenger side goes straight forward, but the one closer to the drivers side goes down behind near the bell housing. At that point I can't tell where it goes.
Does anyone know what it ties into at that point? Does someone have a diagram?
MY PROBLEM: I capped off the coolant line at my throttle body (temporarily) and removed my heater core for replacement. I'm now dripping coolant from behind the engine and down onto my exhaust while the engine is running. I'm not sure if its just some coolant left over in that hose that goes behind the block or if that line ties into another part of the cooling system. If it does tie into another part of the system, that you can't just cap off the throttle body.
Does anyone understand this? (its really late). -dan
Old Jan 1, 2007 | 07:37 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Circulates through the oiler cooler between the oil filter and the block.
Connect the 2 lines at the TB together, do the same for the 2 hoses that connected to the heater core if you haven't replaced it yet.
Old Jan 1, 2007 | 08:30 AM
Fmandan's Avatar
Engine: TPI 350
thanks for the reply! That makes sense. -dan
(you're awesome)
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
