About to set it on fire!
Old Jan 1, 2007 | 02:53 PM
estone06's Avatar
Car: 1991 Camaro RS
Engine: 350 stroker .40 over 11:1 comp
Alright guys, I have a 91 rs with a 383 stroker. i have the correct parts etc...my starter is continuously going out. i went through about 9 total of the auto zone starters in about a weeks time. I went and bought a high dollar starter from oreilly and it has lasted about 100 starts. I have tried the starter with 3 shims to start and it was fine for about 75 cranks, then all of a sudden it was grinding, so i went to only 1 shim, now it has grinded, so i took all the shims out, gave me one good start, and now it grinds. the flywheel is still okay. I am at the conclusion it is a bad starter what do you guys think?
Eddie
Old Jan 1, 2007 | 03:10 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
You need to set correctly set the starter height and depth. When I did my starter in my 67 camaro I has to set all of that stuff. As I remember CSR (a starter company that summit sells) gives you all of the information for checking all of that stuff. I know that my 67 required a special front starter mount block to end up getting my starter drive in the right location. There stuff is not cheap but it your car starts evrythime you'll be done with it. The block that I had to buy was extra from the starter. As i remember it was like $70.00 and I had to purchase it direct from CSR.
That should solve your problems!
Old Jan 1, 2007 | 04:36 PM
estone06's Avatar
Car: 1991 Camaro RS
Well, I am hopeful that that is not my problem lol. I am thinking that since it is a fresh swap and that the starter is for the year block and all is correct with that, that this starter has just worn out and when it engages that there is just a bit ofplay in there. anybody else????
Old Jan 1, 2007 | 09:22 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Have you inspected all the gear teeth on the fly/flex wheel?
Without seeing the damage to the start gear and fly/flex wheel we can only assume that the clearances aren't correct.
Please post pictures of:
Starter
close-up of nose and gear specifically the wear pattern.
Fly/flex wheel gear wear pattern.
Old Jan 2, 2007 | 06:24 PM
estone06's Avatar
Car: 1991 Camaro RS
I thought about it all again and again. I thought that I would take the starter off and take ti to be tested. tested fine. i asked the parts guy to go and grab another one to test it out. when we tested that one, it had kicked quite a bit harder. so i came to the conclusion the teeth when the would kick out of the old starter, they were becoming misaligned somehow internally through the starter. well the new one fixed the problem, thankfully. hopefully, it will be a long, long, long, long term solution.
Old Jan 2, 2007 | 08:47 PM
estone06's Avatar
Car: 1991 Camaro RS
okay well the starter was great for about 10 turns. i went to dinner and just for reassurance went to turn it again, and she is grinding. i have three shims on there right now, i am thinking either 1 shim or no shims, what do you guys say?
Old Jan 2, 2007 | 09:20 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
What do you say to some pictures?
Also include one from underneath, and with the gears meshed.
Old Jan 2, 2007 | 10:27 PM
estone06's Avatar
Car: 1991 Camaro RS
Will take some photos tomorrow morning. I am thinking that I will take all shims out of there and see how the teeth fit up that way first as opposed to three shims on it to start with. I will post photos after I finish it up guys.
Old Jan 3, 2007 | 07:02 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
What year is your engine? The starter pad and holes on lots of early 70's 350's were not machined correctly from the factory and had bad problems, it took a lot of work to get them shimmed correctly. My brother had one that would break the started bolts off after a few months untill I got it shimmed right. And P.S. your engine is not .40 over, it's .040 over!!!
LittleFranks
Sep 17, 2015 12:22 PM
TheExaminer
Aug 26, 2015 04:59 PM
86IROC112
Aug 21, 2015 07:20 PM
TheExaminer
Aug 19, 2015 10:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
