Tune port on early engine?
Old Jan 2, 2007 | 05:02 PM
ibad57's Avatar
Car: Custom 57 Chevrolet Belair
Transmission: automatic
Axle/Gears: stock
Im looking for info on installing Tune Port Inj. on 283 chevy moter
Will it work who might have done this combo.
Old Glory need to breath better curently on half moon 2 barell
visit my web page to see this projeck
http://members.aol.com/ibad57/public...Old_Glory.html
Old Jan 2, 2007 | 06:33 PM
Yes it will bolt right up. No hesitation, reservation or equivocation. Especially if it's a 86 TPI. If it's from 87 up, it'll need the center 2 bolt holes on each side of the intake enlarged.
The bigger question is, why would you want to nut a 283 2-barrel like that?
If you want an upgrade instead of a downgrade, try a 4-barrel carb. A Holley 6210 (650 spreadbore mech sec) was my preferred personal weapon back in the days when all we had was 283s and 327s and their hybrids, and we were trying to run against 396s and Hemis and 351 Clevelands. Probably good for 50 more HP than a TPI on that motor.
Old Jan 3, 2007 | 09:47 AM
ibad57's Avatar
Axle/Gears: stock
My goal is fuel economy and aperance with good throttle responce this project is for shows and traviling. at 2600 lb I dont want to raise single front tire of ground check her out and you see what I talking about
Old Jan 3, 2007 | 02:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Good god...
That's the weirdest thing i've ever seen...
It's a tricyle with the tail end of a '57 Belair on it.
Old Jan 6, 2007 | 01:00 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Then dont put a TPI on it. You put a TPI in the trash, not on your car. Sofa is right...put a quad on it.
Old Jan 6, 2007 | 05:59 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i agree, he will probably see lower horse power than if he had a 4-barrel carb on it, but going from a stock 2-barrel carb to TPI would be an upgrade, i think he will see a nice increase in torque.
he said he wants fuel economy & appearance with good throttle response, he can get that from TPI.
on that thing with a 283, i think 35+ MPG with chip tuning is possible.
after all, at 2600 pounds & with 3 wheels, how fast do you really want to go?
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
355tpipickup
Aug 13, 2015 07:35 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
